MikhailModeratorI will check.
MikhailModerator
MikhailModeratorThank you.
Could you also provide a screenshot of the communication line log when you send a command?
In Rapid SCADA 6 you can set a deadband for a limit. It’s not a time delay but also can be helpful. To make a time delay, you need to develop a formula and change channel status from the formula.
MikhailModeratorFirst of all, try sending command from the device data page (in Communicator settings). Provide screenshots if it doesn’t work.
With DrvHttpNotif you can send any parameters using GET or POST request.
You should send a command having the code Request and text like
grp=value1
value=value2
Yes, there is ModDbExport module in v6. The module was upgraded and improved.
An addition to the above answer: to display a link as a button, set borders and background color if needed.
MikhailModeratorIf your company (or client) uses Active Directory, it’s possible to integrate it with Rapid SCADA and manage users by Active Directory tools.
This reply was modified 2 years, 8 months ago by
The option to assign a user management plugin is created for future use. The plugin itself has not been developed yet. We will develop it in the future.
MikhailModeratorHow did you solve this issue?
MikhailModeratorScheme Editor requires WCF to be installed. Check the Windows features as shown here.
