manjey73ParticipantYou need to specify what you need in the formula for the control channel. Send now always sends 0 if you don’t apply the formula.
manjey73ParticipantI haven’t tried connecting via OPC RSLinx, so I can’t recommend anything. Which Allen Bradley PLC do you want to read and through which interface ?
manjey73ParticipantNo, you don’t need an additional module. You can use animated gifs
manjey73ParticipantThere is another option, you disable the web port forwarding. Create a VPN server on your router. When you need to, connect via your phone as a VPN client and then go to the WEB at the internal address of your server. The VPN client must be able to route the connection to the internal network. One of the advantages of this solution, depending on the settings, your phone when accessing the Internet will be determined with the IP that you have at home
manjey73ParticipantYou need to transfer Apache2 or IIS to work on https. I didn’t do this myself, but the topic on the Russian forum may help, and Mikhail will write more details
manjey73ParticipantThere are just real dynamic addresses, and there are dynamic addresses located behind the provider’s NAT. In the second case, only cloud services or VPN services can help (but I have not met third-party vpn services that would allow you to connect two clients to each other)
manjey73ParticipantYou already have everything installed, you may need to register the server in the apache2 system
You need to look at the apache2 settings
manjey73ParticipantPort forwarding for example
Checking the IP provider, it is not a fact that you will be able to connect to it, since it may be for NAT
For example, routers Zyxel, Mikrotik and perhaps others have a cloud service to access them, then instead of an IP address, you need to know the name that the router manufacturer provides you with
xxxxxxxxxxxa.sn.mynetname.net – On my Mikrotik it looks like this (instead of xxxxx numbers)
manjey73ParticipantID: 0.1.3.6.1.4.1.232.6.2.6.8.1.4.0
Have you tried it ?
manjey73ParticipantThe schema editor has a Link component. Open your mnemonic and see its address in the browser’s address bar, for example http://192.168.0.121/scada/View.aspx?viewID=4 and enter the url in the Navigation parameter
manjey73ParticipantThe individual components of the system have different numbering
manjey73ParticipantIs regular xrdp not enough ?
manjey73ParticipantThe name of the formula is if_S_S not If_S_S
manjey73Participanthttps://github.com/mono/mono/issues/18864#issuecomment-593561532
if the package version does not belong to xamarin6
manjey73ParticipantCheck whether you have libapache2-mod-mono installed. And check what version of the package is, if it is not installed.
