Conection using snmp
Forum Home › Forums › Understanding the Software › Conection using snmp
  • #6715
    nelson.albarran
    Hi, I am trying to stablish a conection between the scada and Server in datacenter room. I configure the IP and Password in the scada, the comunication is ok. But when set the OID, send me error.
    2020-04-07 12:52:57 Communication session with the Device 51 “SNMP”, type: KpSnmp, call number: 192.168.60.205:161
    Get variables of the group “Temp”
    Error getting variables: TimeoutException: timeout: 1000
    How can i solve the problem.
    #6718
    Check that the TCP port 161 is open for incoming connections on the server’s firewall.
    #6721
    nelson.albarran
    The port is open, the log is:
    2020-04-08 19:17:27 Communication session with the Device 51 “SNMP”, type: KpSnmp, call number: 192.168.60.205:161
    Error getting variables: error in response. NoSuchName. Index: 1. Errored Object ID: .1.3.6.1.4.1.232.6.2.6.8.1.4.0
    #6722
    Have you tried it ?
