manjey73ParticipantWhat is Angstrom Linux based on?
I very much doubt that it is possible to install Mono on this OS
If you install Debian, it is possible to start the system. At the expense of using GPIO, you need to look at what is implemented, if there is a libwiringPi assembly, then it is also possible
This reply was modified 4 years, 11 months ago by
manjey73.
manjey73ParticipantTry to remove the check mark – Stay connected in the communication line settings.
manjey73ParticipantThe same garbage for two events, the formulas seem to affect the creation of duplicates.
manjey73ParticipantOn the current version and earlier, you can save data every second, you need to change it manually in one of the configuration files.
manjey73ParticipantWould you share the IEC104 driver ?
manjey73ParticipantIt is necessary to look at the mono version, sometimes in the repositories the version is much younger than is required for Scada to work. Therefore, it is better to install Mono from the developers ‘ site. In the text document, there is an example for connecting a repository in Debian. But it is probably also suitable for Ubuntu, you should try it.
https://www.mono-project.com/download/stable/#download-lin-ubuntu
manjey73ParticipantIn fact, I would recommend using raspbian, because in my experience, all third-party systems most often have errors in the builds, since people do not pay enough attention to the work at 100%, simply because they can not test absolutely everything.
manjey73ParticipantDid you install Mono from where? Perhaps there is an old version in the ubuntu repository and there are errors on this?
manjey73ParticipantConfiguration Database-Directories-Event types
Add your event and specify your color, or use the ones that are there
In the input channel 177, use a formula like this
Val();Val()>0? SetStat(177,116):SetStat(177,117)In this way, you change the channel status number to your own, to which the colors are linked.
manjey73Participantswapnilkumbhar – aburakhin@bk.ru
My English is bad, I use an online translator 🙂
manjey73ParticipantWhat do developers in India mean? you can install and configure Scada remotely, only a person who will connect the wires and an IT specialist are needed on site
manjey73ParticipantOpen the project, open the input channels. File-Export the table, select CSV and perform the export
manjey73Participant
This mechanism does not work in Linux. I haven’t checked what doesn’t work yet. Raspberry is too slow a PC to configure scada directly on it, it is easier to run a project on your Windows PC and upload it to a remote server.
manjey73ParticipantThe interface works, but there are some problems with the display and for the Linux version these mechanisms are disabled. For example, in the settings there are no drop-down menus with a selection of preset values, you must enter numbers. You can make a cheat sheet for all parameters and look at it when setting up, but this is very inconvenient. We expect version 6, where it will probably already work in the GUI on Linux without these inconveniences. All applications running under Mono run as written above, in theory, you can make symbolic links to run.
April 19, 2021 at 7:05 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8784
manjey73ParticipantChange the owner for all folders and files in the folder.
sudo chown -R user:group /path/to/dir/Where user is the new owner and group is the user group. -R indicates that the rights must be changed recursively.
Example for Raspberry and install in /opt
sudo chown -R pi:pi /opt/scada -
