manjey73Participant@manyan2028 127.0.0.1 this is the local IP of the machine, not the IP of the PLC
502 the port is a Modbus port and not a port for the Ethernet/IP protocol, by default the port should be 44818This is according to your screenshot from the mail. Read carefully how the Allen Bradley PLC is polled and exactly how you want to poll it, via Modbus, if it has such an opportunity, or still via Ethernet/IP
manjey73ParticipantDoes your gateway work over Modbus TCP ? Has a port for access, for example 502 ? Perhaps you are requesting an address that is not in the gateway variables
manjey73Participantuse Formula SetVal
Look in the documentation how to use it correctly
manjey73ParticipantUse Autologin for version 5
manjey73ParticipantI may be wrong, but in this case, the trigger should be set to the channel status and apply formulas that change the status.
manjey73ParticipantAs far as I remember, if you have a trigger at 0 and when you restart the server you have 0 there, then the command will be skipped. You need to do 1 in the channel, and then 0, that is, changes must occur. This is done in order not to send commands when restarting the server.
manjey73ParticipantAs far as I know, in the current version of Gate, it is possible to have the same channels on remote servers if the same type of installations. And on the central server, you just clone channels, after setting up the first remote server, then when setting up the second remote server, you simply change the bindings in the Gate settings to the new channels of the central server. Example. You set up the first remote server with channel numbers 1-800 with transmission to the central one also at 1-800, then you clone channels on the central server 1-800 at 1001 – 1800 and when you start the second remote server, you set up communication 1-800 (remote server) at 1001-1800 central. And so on for subsequent servers. I don’t know how it will be in the 6th version, there should be identifiers of a different type and it may be easier.
manjey73ParticipantMost PLCs allow you to read data in the form of Int16, and only then remove the required registers in Scada.
manjey73ParticipantFor example, you can record the maintenance time of some equipment in the calculation channel and then compare it with the current one somewhere and create messages.
myDT(2023, 5, 15, 10, 0)
Year 2023, month 5, 15th, 10 am
manjey73ParticipantYou can make a general formula, for example, for applying a record in the maintenance time channel.
double myDT(double year, double month, double day, double hours, doble minute) // Without seconds
int y = Convert.ToInt32(year);
int mh = Convert.ToInt32(month);
int d = Convert.ToInt32(day);
int h = Convert.ToInt32(hours);
int m = Convert.ToInt32(minute);
return new DateTime(y, mh, d, h, m, 0).ToOADate();
}Then it can be used for different purposes. But you will have to specify the year, month and day every time. For your case, it is simple to specify and set the Time channel format
myDT(2022, 1, 1, Val(6311), Val(6312))
manjey73Participantdouble myDT(double hours, doble minute)
DateTime ddt = DateTime.Now;
return new DateTime(ddt.Year, ddt.Month, ddt.Day, Convert.ToInt32(hours), Convert.ToInt32(minute), 0).ToOADate();
}in channel
myDT(Val(6311), Val(6312))
format channel – Time
But it will show seconds, If you want without seconds, then it will be a text field converted from time, with an indication of the display format and subsequent translation from ASCII to an array of bytes, and the format of the ASCII Text cell
This reply was modified 4 years, 3 months ago by
manjey73.
manjey73ParticipantIt is impossible to make a year, month, day with zeros in this version, I just made a formula in the channel
new DateTime(2022, 1, 1, 2, 3, 0).ToOADate()
Where 2 and 3 are your channels of hours and minutes. Right in the channel they can be written like this
new DateTime(2022, 1, 1, Convert.ToInt32(Val(6311)), Convert.ToInt32(Val(6312)), 0).ToOADate()
manjey73Participantdouble Dt(double hours, doble minute)
return new DateTime(0, 0, 0, Convert.ToInt32(hours), Convert.ToInt32(minute), 0).ToOADate();
}In channel formula Dt(Val(6311), Val(6312))
Format channel – Time
If you transmit only hours and minutes, then in theory this is how it should be
manjey73Participantdouble dt = new DateTime(Year, Month, Day, Hours, Minute, Seconds).ToOADate()
You need something like this, not sure if the formula is correct, not tested. Where, instead of hours and minutes, you should put your data, as far as I remember, by converting it to int
Year, day, etc. can be specified 0
manjey73.
manjey73ParticipantI think you can, you need another calculated channel and use the formula to put it in time. If you are satisfied that it will show the time, but here you need to try with formulas depending on how you want to see the view. The simplest thing is to enter the data in DateTime and tell the channel to display only the time
