Viewing 15 posts - 271 through 285 (of 923 total)
  • in reply to: install Plugin #15630
    You need to put the necessary configuration files in your project, which you then transfer to the Server. You can do this manually by finding the project folder.
    in reply to: install Plugin #15629
    in reply to: install Plugin #15627
    I’m telling you. You have copied all the plugin files according to the folders.
    Then open your project and Download the Configuration.
    The necessary settings files will be uploaded to the project.
    If you try to transfer the server Configuration, since you do not have the settings files yet, they will be deleted on the production server, regardless of whether you are working with the project on the same PC or on a remote one.
    • This reply was modified 1 year, 5 months ago by manjey73.
    in reply to: install Plugin #15626
    Probably this file is not in the project – the Project folder for example HelloWord
    in reply to: Map Plugin not success #15624
    After installing any plugin, you first need to upload the Server Configuration to the project.
    This is probably why you do not have a configuration file, since you have transferred a project in which this file does not exist yet, it is only in the web part after copying the plugin.
    in reply to: install Plugin #15621
    This is true for all plugins. In order for them to run, they must be copied to the runtime server and to the development server, as well as the runtime server configuration downloaded to the project.
    in reply to: install Plugin #15620
    Copy the plugin to the runtime server, as well as to your PC, where you are developing. Then you open your project (not necessarily Hello World) And download the configuration from the server to the project.
    Then you add a plugin, and passes the configuration to the server. After that, you will have the opportunity to register – information about the PC key when the plugin starts on the server.
    in reply to: Conecction wirh DNP3 #15605
    There is no access
    in reply to: Conecction wirh DNP3 #15603
    Are you looking for the cheapest option to read DNP3?
    Perhaps you should really look for another Scada solution where DNP3 is supported?
    in reply to: Conecction wirh DNP3 #15602
    Toshiba TB 1000 – the Internet says it’s a hard drive.
    It is not so important, since you use Windows for Scada, then both OPC DA and OPC UA servers for the DNP3 protocol will suit you. But I would look to the future and look specifically for an OPC UA server for this protocol. As they say, look for the pocket (the price that suits you)
    in reply to: Conecction wirh DNP3 #15598
    Well, first you need to find an OPC server for DNP3. Depending on the OS, it can be either OPC DA or OPC UA.
    Which OS are you installing Rapid Scada on?
    in reply to: Conecction wirh DNP3 #15596
    Either a gateway or an OPC server.
    There is no native DNP3 driver in Rapid Scada.
    in reply to: DrvSmsBu 6.3.0 additional channels #15575
    DrvSmsBu 6.3.0.1
    Replaced the channel with the Unicode string type. Now accepts in Russian (or any Unicode) and English normally.
    in reply to: OPC Server #15554
    modbus is integrated into the system
    There is nothing for Bacnet. What OS do you have? You can use OPC from Insat (Russian) or any other company.
    in reply to: Implementing chirpstack app with RapidScada #15551
    But there is a gateway-bridge and a rest api that can be used when writing a driver or module. And you can also try importing from Influxdb
