Viewing 15 posts - 1,231 through 1,245 (of 6,225 total)
  • in reply to: Any questions about Rapid SCADA and Raspberry Pi #13978
    Rapid SCADA 6 works on Raspberry Pi 3, 4 and 5.
    in reply to: web station bug #13974
    Make sure that the size of the scheme document is large enough to contain all components. Otherwise, there can be side effects.
    https://ibb.co/mTZdnLz
    in reply to: Recipe in Scada #13973
    Dear Marko,
    Could you describe in more detail how this should work?
    in reply to: Web Station Error 500 #13972
    By default, the Server service opens TCP port 10000. If it is used by another app, clients cannot connect. Check the TCP ports in use. If you have a clean virtual machine, it would be easier to try installing there.
    in reply to: OPC UA Server #13971
    Password here is encoded.
    AutoAccept = true
    ConfigFileName = DrvDsOpcUaServer.xml
    DeviceFilter =
    Password = B9D0F030265751578B00E9801C69320C
    Username = opc
    in reply to: OPC UA Server #13970
    By default
    Username: opc
    Password: scada
    You can change them using the data source properties form.
    in reply to: web station bug #13962
    Possibly, a scheme size may be the cause of the issue. If your page is available online, I can check it.
    in reply to: data archiving or redundancy. #13961
    Redundancy is a big topic.
    In short, you could deploy 2 Rapid SCADA servers that poll the devices in parallel independently. This would be the simplest way.
    More complex solution can synchronize data between 2 Rapid SCADA servers.
    in reply to: Event Log #13960
    You should ask @romiros
    As far as I know, the plugin has not yet ported to v6.
    in reply to: More detailed archive classification #13959
    You can create several archives, and assign archives to the channels.
    in reply to: Webserver installation isssues #13958
    Please provide additional info:
    1. What Rapid SCADA version do you install?
    2. What is the OS version?
    Check that AspNetCoreModuleV2 is installed as shown here.
    in reply to: Web Station Error 500 #13952
    I recommend to check that AspNetCoreModuleV2 is installed:
    https://rapidscada.net/docs/en/latest/installation/install-windows
    The web application is executed by IIS, you should not be started manually.
    in reply to: web station bug #13950
    Can you reproduce this issue on https://rapidscada.net/scada/ ?
    If your page is available online, I can check.
    in reply to: Web Station Error 500 #13949
    You should check the web application log, ScadaWeb.log, for the details.
    in reply to: 503 Error #13948
    What version of Rapid SCADA do you use?
    Did you check ScadaWeb.log?
