Viewing 15 posts - 1,201 through 1,215 (of 6,225 total)
  • in reply to: Current Data sudden become Not Ready #14081
    OK. Save log files in case of error.
    in reply to: Flux is entered maintenance mode #14078
    Do you use InfluxDB with Rapid SCADA?
    in reply to: Flux is entered maintenance mode #14077
    Thank you. That is interesting. I guess, InfluxDB will go through a period of instability because of so significant changes.
    in reply to: Running .net8 assembly with mono installed #14076
    I suppose, Mono is outdated.
    To use ScadaAdmin with Wine, build it using the following command:
    dotnet publish ScadaAdmin.sln -c Release -r win-x64 --self-contained true -p:PublishReadyToRun=true -p:PublishSingleFile=true -p:IncludeNativeLibrariesForSelfExtract=true
    in reply to: Current Data sudden become Not Ready #14071
    Archive configuration is displayed when you open its properties.
    Log files are located in SCADA\ScadaServer\Log directory. You should enable the detailed log in the archive properties.
    in reply to: Running .net8 assembly with mono installed #14070
    I’m good. Thank you. Hope you are well too.
    You could try to run ScadaAdmin by the command
    dotnet ScadaAdmin.dll
    to be sure that it is not run under Mono.
    Is it on Windows?
    in reply to: New release Rapid SCADA 6.2.x #14069
    .NET 6 is not required.
    Can the compiled assembly be run with dotnet-runtime-6 or also requires runtime-8 ?
    An assembly can be compiled to support several runtimes. Rapid SCADA applications since v6.2 require .NET 8.
    in reply to: Current Data sudden become Not Ready #14064
    Could you provide the screenshot of the archive configuration and archive log file?
    in reply to: Error uploading configuration #14062
    According to the screenshot, the compressed size of the project is more than 350 MB which is probably too heavy.
    I suggest the following:
    1. Open the project folder in Windows file explorer.
    2. Search for all files of the project, display them as a table and sort by size.
    3. Make a screenshot of the biggest file names and sizes.
    in reply to: Computer Code #14057
    Perform the list item #10 from the manual.
    in reply to: Server is unavailable #14055
    Download ScadaTestClient and try to connect to Server with different usernames: ScadaComm and ScadaWeb. Usernames are set in ScadaTestClient.xml
    in reply to: Server is unavailable #14053
    Could you open the project SCADA\ProjectSamples\HelloWorld\HelloWorld.rsproj in the Administrator app and upload again?
    in reply to: security vulnerability of Rapid SCADA #14051
    Ready to discuss specific security-related issues together.
    in reply to: Ngix Further configuration is required. #14050
    > 2024-02-09 09:35:24 [tomasz-Latitude-5480][root][INF] The application is ready for operating
    This line means that the web application works correctly. You should check the nginx configuration. Check that you performed the item 5c described here.
    in reply to: Display data from a calculation in a deviceless channel #14041
    Could you clarify the question and provide an example screenshot?
