Ngix Further configuration is required.
Forum Home › Forums › Installation Issues › Ngix Further configuration is required.
  • #14037
    Tomasz
    Hello
    I want login fo scada :http://localhost
    Result:
    Welcome to nginx!
    If you see this page, the nginx web server is successfully installed and working. Further configuration is required.
    For online documentation and support please refer to nginx.org.
    Commercial support is available at nginx.com.
    Thank you for using nginx.
    What I schould to do
    #14038
    Do you use Linux?
    Please open the Administrator application, open the HelloWorld project and check the log file of the Webstation application.
    Or just find logs in the file system and check ScadaWeb.log.
    #14043
    Tomasz
    Hi.
    I have Ubuntu.
    ScadaWeb.log:
    024-02-09 09:35:13 [tomasz-Latitude-5480][root][ACT] Webstation 6.2.0.0 started
    2024-02-09 09:35:13 [tomasz-Latitude-5480][root][ACT] Storage FileStorage 6.1.0.0 loaded from file /opt/scada/ScadaWeb/FileStora>
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgChart 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgChart.dll
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgMain 6.0.3.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgSchBasicComp 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgSch>
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgStore 6.0.0.0 loaded from file /opt/scada/ScadaWeb/PlgStore.dll
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgWebPage 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.>
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Receive the configuration database
    2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ERR] Error checking server connection:
    Connection refused [::ffff:127.0.0.1]:10000
    2024-02-09 09:35:24 [tomasz-Latitude-5480][root][ACT] Receive the configuration database
    2024-02-09 09:35:24 [tomasz-Latitude-5480][root][ACT] The configuration database has been received successfully
    2024-02-09 09:35:24 [tomasz-Latitude-5480][root][INF] The application is ready for operating
    • This reply was modified 2 years, 8 months ago by Mikhail.
    #14050
    This line means that the web application works correctly. You should check the nginx configuration. Check that you performed the item 5c described here.
