Error uploading configuration
Forum Home › Forums › Runtime Bugs › Communicator Bugs › Error uploading configuration
Viewing 14 posts - 1 through 14 (of 14 total)
  • #14059
    guilherme
    This error is constantly appearing on anything uploaded.
    Error: Unable to read data from the transport connection: A connection attempt failed because the connected component did not respond correctly after a period of time or the established connection failed because the connected host did not respond.
    https://ibb.co/bH7ys55 – Error uploading configuration
    https://imgur.com/a/sELXhgR – Error uploading configuration
    Adding information presents this error, I remove what I had added and the error appears again, I add the same information sometimes it goes
    • This topic was modified 2 years, 9 months ago by Mikhail.
    #14062
    According to the screenshot, the compressed size of the project is more than 350 MB which is probably too heavy.
    I suggest the following:
    1. Open the project folder in Windows file explorer.
    2. Search for all files of the project, display them as a table and sort by size.
    3. Make a screenshot of the biggest file names and sizes.
    #14455
    Researcher
    I am receiving the follow error after creating a table folder/file and attempting to upload the configuration:
    https://ibb.co/9TRPcy4
    #14459
    Creating which file causes the error?
    Please check ScadaAgent.log for the error details.
    #14470
    Researcher
    I received the error attempting to upload the configuration after creating a new file for a “Table View”. See screenshot https://ibb.co/9H3pT88
    The below is from the ScadaAgent.log. Is this the error? (changed my personal computer information to “MyComputer”.
    2024-04-25 15:48:56 [MyComputer][MyComputer][ACT] User ScadaAdmin is successfully authenticated
    2024-04-25 15:48:57 [MyComputer][MyComputer][ACT] Receive file [Agent]\[Temp]\upload_config_7361909534725472366.zip
    2024-04-25 15:48:57 [MyComputer][MyComputer][ERR] Error processing request 0x0104 for client 127.0.0.1:
    System.IO.FileNotFoundException:
    File name: 'System.IO.Compression, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
       at Scada.Agent.Engine.ScadaInstance.UnpackConfig(String srcFileName)
       at Scada.Agent.Engine.AgentListener.ProcessFile(ConnectedClient client, RelativePath path, Object uploadContext)
       at Scada.Server.ListenerBase.UploadFile(ConnectedClient client, DataPacket request, ResponsePacket& response)
       at Scada.Agent.Engine.AgentListener.ProcessCustomRequest(ConnectedClient client, DataPacket request, ResponsePacket& response, Boolean& handled)
       at Scada.Server.ListenerBase.ProcessRequest(ConnectedClient client, DataPacket request)
    • This reply was modified 2 years, 7 months ago by Mikhail.
    #14474
    The error is unusual. Is that possible that an antivirus system deletes the files like upload_config_*.zip, so the Agent service cannot unpack them?
    Can you see any uploaded files in ScadaAgent\Temp directory?
    #14475
    Researcher
    There are no files in the ScadaAgent/Temp directory.
    #14476
    Can you upload the HelloWorld project successfully?
    It is located in the SCADA\ProjectSamples directory.
    #14486
    Researcher
    No, I get the same error message when trying to upload the HelloWorld project.
    #14488
    Please run cmd with the command
    dotnet --info
    and copy the results here.
    Seems that System.IO.Compression.dll, which is included in .NET, is not found.
    #14493
    Researcher
    Here are the results from running the dotnet command
    https://ibb.co/7CQ9b82
    #14496
    .NET version is OK.
    Do you have an option to test the software on another machine?
    #14547
    Researcher
    I installed the software on another computer, and I am no longer receiving the configuration error.
    Thank you for your help!
    #14564
    Thank you for the info.
    Probably, the issue was caused by .NET installation problem.
