Forum Home › Forums › Understanding the Software › security vulnerability of Rapid SCADA
- This topic has 5 replies, 2 voices, and was last updated 2 years, 9 months ago by
February 7, 2024 at 11:08 am #14016
grhsc
ParticipantDear Developer,
I saw the information about the Rapid SCADA security vulnerability,
https://www.cncso.com/en/multiple-high-risk-security-vulnerabilities-in-rapid-scada.html
This article specifically mentions – Rapid SCADA developers have been notified of the vulnerability in July 2023, but no patch has been released as of this date.
I saw from cisa’s report that this is a vulnerability for version 5.8.4 and prior, so I don’t think the description above is accurate, is it?
https://www.cisa.gov/news-events/ics-advisories/icsa-24-011-03
Does it still have these potential issues with the V6?
Your clarification will help give me and all Rapid SCADA fans confidence, thanks in advance!February 8, 2024 at 9:05 am #14021
We also checked those CISA reports some time ago. The above links does not contain steps to reproduce the issues, therefore I can answer in general.In v6 the following security improvements were made:
1. Encrypt passwords in configuration files.
2. Store only password hash for user passwords.
3. Encrypt sensitive information in TCP application protocol.
4. Brute force protection.
5. The web app can redirect only to a local page on user login.
6. Use more secure default installation directory on Windows.February 8, 2024 at 9:10 am #14022
MikhailModeratorWhat you should do to protect the system:
1. Follow the safety recommendations.2. Restrict access to your project. It’s recommended to store project on GIT in private repository. It helps to control any changes made in the project.
If an attacker changed your project, he could access the server’s filesystem by read and write operations from the scripts. Also he could add hyperlinks to external resources on the schemes.3. Restrict access to the production server. It’s obvious.
Use firewall.4. If Rapid SCADA is hosted in the cloud, enable captcha and use Guard Plugin for additional security.
5. Use strong passwords in production environment. Change all default passwords.
6. Run Rapid SCADA services with lower privileges instead of system (root) user.
February 8, 2024 at 9:14 am #14023
MikhailModeratorNote that you can find similar security reports for any well known SCADA software. Since Rapid SCADA is open source, its internal structure has been tested by many professional developers and we respond to their feedback.
There are many Rapid SCADA instances available on the Internet that work reliably for many years.
February 12, 2024 at 4:19 am #14044grhsc
ParticipantThanks for the clarification and security guidance!
February 12, 2024 at 11:21 am #14051
MikhailModeratorReady to discuss specific security-related issues together.
