Viewing 15 posts - 976 through 990 (of 6,219 total)
  • in reply to: DB export #14714
    Don’t forget to check variables available in a SQL request.
    in reply to: DB export #14713
    If I understand the question correctly, you need to execute a SQL query on a command. First, try sending a command manually by a user. Note that SetData() function does not send a command. To send commands according to conditions, use Automatic Control Module.
    in reply to: TCP/IP Problem #14712
    ByDriver means that a driver parses an incoming request to decide what device the request belongs to. It is usually used in slave mode when we cannot identify device by IP or hello packet.
    in reply to: TCP/IP Problem #14711
    The existing configurations belong to project owners, so can’t be shared. Provide screenshots of your settings to check.
    Note that after connection a modem should send a “hello packet” to identify a device. If it’s not supported by the modem, you need to use different TCP port for each device.
    Configure a Modbus Slave device. Then you will find the code in ScadaComm.log
    in reply to: Logging Data per second #14701
    Archive kind should be Historical.
    The Is Default checkbox should be unset.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #14700
    The above link is not public.
    The issue does not seem Raspberry specific. I suggest to find a proper topic related to MQTT communications for continue.
    in reply to: Error: Garbage collecctor… #14698
    Mono framework can have memory leaks. .NET 8 is much better.
    > When I upgrade to version 6, do I need new license keys?
    First, try the existing keys. We can upgrade the keys for the same machine for free if needed.
    in reply to: Historical data report achieve copy #14697
    Thank you for the info about the result.
    in reply to: TCP/IP Problem #14696
    If a communication line is working as TCP server, make sure that incoming connections are enabled in the firewall settings.
    in reply to: TCP/IP Problem #14695
    Usually 4G modems are not available by IP from outside. Telecom operators sell white IP addresses. Another solution is using VPN.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #14687
    The above advice is correct.
    @arunruchir
    , could you provide screenshots of the settings and device data page?
    • This reply was modified 1 year, 9 months ago by Mikhail.
    in reply to: Error: Garbage collecctor… #14686
    Looks like an out of memory error. How long does it work after rebooting the Raspberry?
    In general, I recommend to upgrade to Rapid SCADA 6 which uses modern .NET framework.
    in reply to: TCP Server Connection Issue #14685
    As I remember Moxa NPort has such settings, for example.
    in reply to: Historical data report achieve copy #14684
    No, I mean changing only the Kind cell to empty value.
