Viewing 8 posts - 6,211 through 6,218 (of 6,218 total)
  • in reply to: Modbus simulator #72
    Switch to Communication Line log tab.
    Read the log carefully, usually it contains information about the cause.
    Firstly, realize is the connection established or not.
    in reply to: WCF Service error #71
    The error is concerned with a security reason. Scheme is displayed by the silverlight application which can’t connect to WCF service.
    Try to open SCADA-Web using different URLs:
    http://localhost/scada
    http://127.0.0.1/scada
    http://YourComputerName/scada
    Does it solve the problem?
    in reply to: Users and passwords #70
    The system works exactly as you described. It is not a bug. The goal of the passwords in SCADA-Server shell and SCADA-Communicator shell is let a user think for a few seconds before sending data or command.
    It is proposed that the user who has administrative rights on a server required to start SCADA-Server and SCADA-Communicator is accepted to control SCADA.
    in reply to: Scada Server connection problemes #66
    Of course you can add new users and modify the existing.
    Try to do a one modification and if the system works strangely post a question to Understanding section with description of changes and symptoms.
    Could you make a separate topic about WCF service error?
    in reply to: Data simulation #65
    Dear Teleco,
    Probably you didn’t modify status of sent data using Generator. Set status >= 1 to display the value in SCADA-Web.
    Anyway you are able to control sent value and status directly in the archive files those can be opened by SCADA-Server.
    SCADA-Communicator “doesn’t know” about values sent by Generator. It dispays error if no connection with device has been established.
    in reply to: Scada Server connection problemes #61
    I think you should restore User table in the configuration database. Do the following:
    1. Open SCADA-Administrator and make a backup of the configuration database.
    2. Clear all the data from Users table.
    3. Unzip user.dat from ScadaAdmin.zip of the installation packege and overwrite the existing file.
    4. Import user.dat into the configuration database.
    5. Restart SCADA-Server.
    Open http://localhost/scada and try to connect as: admin
    Default password: 12345
    in reply to: Scada Server connection problemes #59
    Did this issue appear just after the installation of Rapid SCADA or after configuring?
    If you make some changes using SCADA-Administrator before the problem occurs please describe them.
    “http:\\127.0.0.1 in browser bar it shows me the IIS8 initial site” – it’s OK.
    • This reply was modified 11 years, 2 months ago by Mikhail.
    in reply to: Installation errors #56
    Dear Akbarm,
    Please post the following additional information about the issue:
    1. What were the errors occured during installation?
    2. What is the state of SCADA-Server when it runs? The state is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt
    This issue often appears if some other application uses TCP port 10000. For example, torrents client. In this case, close that application and restart SCADA-Server service.
