Viewing 15 posts - 5,731 through 5,745 (of 6,219 total)
  • in reply to: how they work: Events, Alarms and Limits #1279
    Something wrong with the image.
    It requires changes in SCADA-Server logic. The changes may be done within a common queue of tasks or may be done fast for a fee.
    As a workaround, limits can be implemented using formulas, but in this case you need separate channels for alarm signalling.
    in reply to: how they work: Events, Alarms and Limits #1274
    Do limits are set for those channels?
    in reply to: how they work: Events, Alarms and Limits #1270
    Uncheck Event on undefined checkbox for these channels.
    in reply to: Copyright on footer #1267
    Please, remind me by email to send you the prototype.
    in reply to: Copyright on footer #1265
    OK, the color and font of the link are not important for me. The link should be visible to users and be clickable. Could you show me a design when its beta version will be ready?
    I have to warn that the new web app is fully redesigned and when it will be released, you will need to make design with your brand again. May be it’s better to use the new design as a base. I can send you the prototype.
    in reply to: Copyright on footer #1263
    Could you add a link to rapidscada.org with a text like “Powered by Rapid SCADA” near “designed by”?
    in reply to: Integrating android panel with BacNET #1259
    If you have got a schema of your system, please post it here or send by email. I need deep understanding the communications between the components of the system.
    in reply to: Integrating android panel with BacNET #1257
    BACnet becomes more and more popular. For the time, you should use 3rd party software or hardware gate to connect BACnet devices to Rapid SCADA. The discussions about BACnet support are here and here.
    It is possible to develop a native driver that allows to connect BACnet devices to Rapid SCADA directly. We can discuss the development.
    We are planning to release the new modern Rapid SCADA web app provides web UI which works well on different types of clients including Android and iOS. It will be released within a few months.
    in reply to: New Web App Idea? #1255
    This idea requires development an additional module for SCADA-Server. It’s interesting.
    i will have 10 undefined events
    You can create a calculated channel to determine the state of connection instead of using “undefined” events.
    in reply to: Several days/channels graphs are generated slooooowly #1254
    When I start a work of porting the chart component to the new web app, I will do an optimization. Thank you for the useful information, you saved my time.
    in reply to: Several days/channels graphs are generated slooooowly #1251
    Probably it keeps all the data in a cache.
    Are the client and the server on the one PC?
    in reply to: Contract Agreement for the modules and invoice #1249
    Yes, all you listed can be prepared if required.
    in reply to: Several days/channels graphs are generated slooooowly #1248
    Thanks!
    If somebody are able to compare the charting speed with other SCADA software, it would be very interesting and useful.
    in reply to: Several days/channels graphs are generated slooooowly #1244
    The issue is enqueued.
    in reply to: Firefox left w/ graphs open overtakes RAM #1243
    I’d prefer not to promise. In the summer it has to be released )
