Viewing 15 posts - 5,686 through 5,700 (of 6,219 total)
  • in reply to: Export to excel and Table view #1389
    To export the table view and events find a button with Excel icon on the main page of the web app (Main.aspx). To export minute data goto to reports page (Report.aspx) and choose Minute data report.
    in reply to: Unable to load http://localhost/scada #1388
    IIS seems OK.
    Did you install Rapid SCADA in C:\SCADA\ScadaWeb folder?
    Please check if the folder C:\SCADA\ScadaWeb exists and contains any files.
    If the folder doesn’t exists, try to reinstall SCADA-Web.
    in reply to: How to modify many database fields content easily? #1385
    The great approach! I think it should be included in the SCADA-Server shell.
    in reply to: PLC data in flat files. #1384
    Please, send me an email request. The address is here.
    Also provide the following info:
    1. What kind of data should be written in files:
    – current data sent by devices,
    – historical data,
    – events?
    2. How to clean the outdated data?
    3. What is the due date?
    4. Any additional requirements?
    in reply to: Graphs: unlimited channels and multicolumn legend? #1379
    I wonder if you are already using SQL Server lite for objects/channels… why not for data too?
    Pros of file storage:
    – Performance
    – Works great on systems with low resources, e.g. Raspberry Pi
    – Easy to refactor depending on the project needs
    – No dependencies on 3rd party
    Cons:
    – Unable to write SQL requests
    – Unable to retrieve data using standard tools
    The ideal way is to implement the ability to use different data storage engines.
    in reply to: PLC data in flat files. #1377
    You need to develop or purchase a module for SCADA-Server. Use this one as an example.
    in reply to: Graphs: unlimited channels and multicolumn legend? #1376
    This limit is defined in DiagCnls.aspx. You can change it, I think it should work.
    You right, the possible problems are layout and performance.
    How many channels do you compare in the work proccess?
    in reply to: OPC Server in RapidSCADA #1373
    Please, create a new topic, this one is not appropriate. Furthermore, provide more details about your task.
    in reply to: How to modify many database fields content easily? #1370
    You should use srezAdapter.Update(srezTable) method after modify data in srezTable.
    Changing data:
    https://github.com/RapidScada/scada/blob/master/ScadaServer/ScadaServerCtrl/FrmSrezTableEdit.cs#L331
    Saving: https://github.com/RapidScada/scada/blob/master/ScadaServer/ScadaServerCtrl/FrmSrezTableEdit.cs#L103
    “Srez” means a snapshot ))
    in reply to: System Crash #1369
    For the old web app you should enter views into the Interface table if you need custom user roles. For the new web app all the views must be in the Interface table.
    in reply to: System Crash #1366
    Are you talking about the new web app or about the current version? My note was about the new.
    in reply to: System Crash #1364
    The server code of the all Rapid SCADA applications are highly stable, and the apps work for months and more without restarting.
    The issue may occur with a browser on a client side if the browser doesn’t be reopened for a few hours. The new web application which works great is under active development. You can install the prototype (see this link)
    in reply to: New Web App Idea? #1363
    For now the prototype supports schemes, table views and events.
    Charts, commands and reports are under construction.
    Use fresh version of Chrome (recommended), Firefox or Edge. It also works on iOS and Android. Don’t forget to update your browser.
    In case of issues, please, create new topics.
    in reply to: New Web App Idea? #1362
    I have published the prototype http://rapidscada.org/download/scada_web_beta.zip
    Look for installation instructions in manual_setup_en.pdf of the main distributive package.
    The files of the prototype have to be located in C:\SCADA\ScadaWebBeta\
    Define views using SCADA-Administrator as shown on the screenshot
    postimage
    Then enter view IDs in the file C:\SCADA\ScadaWebBeta\ViewSettings.xml
    in reply to: Using formulas bit confusing #1360
    Function and variable names are case sensitive. Check it.
