Forum Home › Forums › Development and Integration › Graphs: unlimited channels and multicolumn legend?
- This topic has 4 replies, 2 voices, and was last updated 10 years, 3 months ago by
inpelsa.
June 30, 2016 at 10:12 am #1374
inpelsaParticipantHello,
I know it could be a bad idea, but at the end it depends on the person who implements it and their hardware performance…
It would be useful sometimes to show 15-20-50-unlimited? channels on a graph. It could leverage to problems but showing an alert ‘Too much channels shown affects performance’ should leave responsability to the end user.
Nowadays having a 22″ monitor is common and showing a graph with 20-30 channels at 1920×1600 pixels on it is “”not”” a problem. The only limit I see is the legend who could overtake the display.
A multicolumn (always balanced or only over 10 channels) legend could help on this. Maybe values are not so readable but it’s up to you and is very useful on comparing several channels!
bye bye!
June 30, 2016 at 2:09 pm #1376
This limit is defined in DiagCnls.aspx. You can change it, I think it should work.
You right, the possible problems are layout and performance.How many channels do you compare in the work proccess?
June 30, 2016 at 3:36 pm #1378
inpelsaParticipantYahooo !!
About 15 channels by now. but who knows in the future?
20 channels, 15 days, works perfectly (but with that [show data] function disabled)
I wonder if you are already using SQL Server lite for objects/channels… why not for data too?
I’m sure it will be mandatory soon or after for a number of data related reasons.
Sending several days data together to the graph will make it even faster.July 1, 2016 at 8:09 am #1379
MikhailModeratorI wonder if you are already using SQL Server lite for objects/channels… why not for data too?
Pros of file storage:
– Performance
– Works great on systems with low resources, e.g. Raspberry Pi
– Easy to refactor depending on the project needs
– No dependencies on 3rd partyCons:
– Unable to write SQL requests
– Unable to retrieve data using standard toolsThe ideal way is to implement the ability to use different data storage engines.
July 1, 2016 at 9:14 am #1380
inpelsaParticipantOn the performance… not sure, maybe it’s faster because you only access sequential data without filtering, grouping… but I’m curious to see a performance benchmark between both solutions. Current databases can get profit of new technologies, and if they are worth, it can make the difference.
I’m on Arduino, I understand that point, on those platforms it’s a completely different situation and at some point they will use newer technologies.
There is SQLite for the Pi, but dependencies will be still there.
That ability is the best, for sure, but I think in 1-2 years will not be needed anymore as said. Just switch to SQL at the right moment 🙂
