OPC Server in RapidSCADA Forum Home › Forums › Uncategorized Issues › OPC Server in RapidSCADA This topic has 5 replies, 2 voices, and was last updated 9 years, 4 months ago by Mikhail. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts June 15, 2016 at 12:33 pm #1307 PraveenParticipant Hello, Can RapidSCADA be used as OPC server? I need get the data from Modbus PLC to the SCADA system and need send the data to other system through OPC server or by any other means. Is that possible in RapidSCADA? Thank you. June 15, 2016 at 3:20 pm #1308 MikhailModerator Hello, For now Rapid SCADA works as OPC client, not as OPC server. May be you can use DB, such as MySQL, for the integration purpose? June 25, 2016 at 9:22 am #1334 PraveenParticipant Hi, How to write values to MySQL? Is there any direct way? (or) do we need to write application to read from dat files and write to MYSQL? With B/R, Praveen.B June 25, 2016 at 6:02 pm #1341 MikhailModerator Hi, See http://forum.rapidscada.org/?topic=writing-additional-data-for-example-infotext-to-historical-db/#post-904 June 29, 2016 at 1:00 pm #1372 PraveenParticipant Hi, I need to read data for every 30 minutes and want to write it to file. So I am interested only last 30 minutes data, whenever I try to read. And also I want automate this process. Is there any good way of doing this? Thank you. June 30, 2016 at 5:37 am #1373 MikhailModerator Hi, Please, create a new topic, this one is not appropriate. Furthermore, provide more details about your task. Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
