Lora is a very common name. You should check the documentation of your Lora gateway and find information how it can provide data for the SCADA software. May be it can work in transparent mode so you could receive data in Modbus format.
MikhailModeratorI’ve added that feature to the backlog.
Do you mean that channels should be searched recursively under a parent object?
You can try to build and activate 2 plugins: PlgMimic and PlgMimicEditor. But they are on early stage.
When they are ready enough, I will publish a demo.-
This reply was modified 11 months ago by
MikhailModeratorYou could try to insert an Elastic Report in HTML format as a web page view.
It will display what you need, but without automatic refresh.-
> When the channel value is 0, the channel will not be displayed in the table.
Table view cannot switch channel displaying.
In a scheme view, it’s possible to change an image depending on channel value, so it will solve the question for discrete channels.
Automatic login is the same for the entire web application.
To use another login/password, deploy an additional instance of the web application. It can be done on the same or another computer.
> Rapidscada and the OPC DA Server are running on different machines.
When OPC DA server and client are installed on different machines, it requires setup of DCOM security. You should search for DCOM manuals. Sometimes a user manages to run it.
I recommend installing Communicator on the same machine where the OPC server is already installed.
Schemes can display current data as a table. However, it requires manual data binding between cells and channels.
MikhailModeratorReceived. What hardware, operating system and file system is used?
MikhailModeratorIf writing an event is not properly finished because of power outage, new events will be successfully written in the file when server continue operating.
An exception situation like “Event marker not found” occurs when an event file is corrupted, i.e. contains invalid data.
If you need this issue solved, publish the corrupted file to be possible to analyze it it’s possible to restore them or not. If the problem occurs often, a special module can be developed to check and restore corrupted event files before the Server service starts.
MikhailModeratorMerged to https://rapidscada.org/download/lang_pack/lang_pack_2.2.zip
MikhailModeratorLikely, the directory that are set by default does not exist. Choose the correct directory by clicking the Browse button.
MikhailModeratorPlease check the selected “Trend table directory”. Does it contain data files?
Can you view historical data via the web interface?
MikhailModeratorMQTT Publisher sends data tag by tag. Payload format is configurable. I suggest to try. It does not require much efforts.
