Viewing 15 posts - 4,546 through 4,560 (of 6,219 total)
  • in reply to: Users, roles, rights #4304
    Thank you. Be free to ask 🙂
    in reply to: "Unable to login : Server is unavailable" Problem? #4303
    2018-09-21 02:54:40 Error compiling the source code of the formulas:
    This message means that there is a problem in a formula of input channel. You should fix the formula and restart the Server service.
    See line 571 in C:\SCADA\ScadaServer\Log\CalcEngine.cs to find out what is the formula is incorrect.
    in reply to: Users, roles, rights #4299
    Users of the Guest role can view all. If you don’t want it, create your own custom role and apply it to the user named “guest”.
    in reply to: Rapid Scada sleep? #4298
    You should research what the services do when they not respond.
    Check logs of Server and Webstation.
    in reply to: Hysteresis on input channel… #4297
    Hi Josef,
    Other approach that may be easy to understand:
    1. Install Automatic Control Module and create triggers that will raise commands on your conditions. There are delays and deadbands available.
    2. Create an output channel and use SetVal() function to change a corresponding input channel.
    in reply to: I can not Activate Installed Plugins. #4296
    1. Try to delete WebSettings.xml.bak manually.
    If it doesn’t help:
    2. You should open properties of the C:\SCADA\ScadaWeb\config\ folder and allow read/write access to a user that is written in C:\SCADA\ScadaWeb\log\ScadaWeb.log
    I often provide access for all users, but this is not secure.
    Apply changes recursively.
    in reply to: "Unable to login : Server is unavailable" Problem? #4295
    Have you tried the above advice?
    What is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.log ?
    in reply to: Users, roles, rights #4286
    This is not necessary to add admin and guest to the Rights table. These roles are standard.
    The screenshots are clear. I didn’t catch what goes wrong? ))
    in reply to: OPC write value issue-IBH opc server #4285
    Writing issue: use Matrikon OPC to compare. If it works, the cause is related to the particular OPC.
    in reply to: OPC write value issue-IBH opc server #4284
    I need to restart the computer to use again the server
    Try restarting Communicator service.
    in reply to: Channel types description #4273
    1. Please open Administrator, open the Channel types table and find the descriptions.
    2. What is the context?
    In most cases, tag means variable in SCADA.
    3. Yes
    Link 1
    Link 2
    Link 3
    in reply to: Please advise Extra Scheme Components Plugin #4272
    Try unblocking PlgSchExtraComp.dll
    Example
    in reply to: Please advise Extra Scheme Components Plugin #4270
    Hi Phachakorn,
    Does ‘C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ file exist?
    What is the installation directory of Rapid SCADA? I suppose C:\SCADA\
    Note: Because your company purchased Extended support subscription, you also can solve issues by email or ticket tracker which is faster than forum. It’s up to you.
    • This reply was modified 7 years, 6 months ago by Mikhail.
    in reply to: OPC write value issue-IBH opc server #4269
    > Tag value has been passed to OPC server. Name: PLC1.Generic.sensor-nivel-bajo-tanque-principal
    The above line says that the command is sent.
    What OPC server do you use?
    Can you try sending commands to Matrikon OPC for testing reason?
    What communication protocol is used by the PLC?
    in reply to: Users, roles, rights #4264
    Could you provide screenshots of the settings and of the web app?
