Viewing 15 posts - 4,411 through 4,425 (of 6,219 total)
  • in reply to: Generate Event using formula #4698
    I agree that this is an important issue. Thanks for paying attention to this.
    in reply to: HTTPS on Linux #4694
    I asked for a screenshot but I see *.json file.
    in reply to: Chart Pro Y Axis scaling #4693
    I sent you an email.
    in reply to: OPC write value issue-IBH opc server #4690
    Is there a method like Connect to connect to the OPC server?
    in reply to: HTTPS on Linux #4689
    There is no screenshot by this link. At least on my PC.
    in reply to: output channel input channel properties #4688
    It affects hourly table views.
    When you see “rockets” at http://demo.rapidscada.net/View.aspx?viewID=22 near Light and Aeration, this is because of this column.
    in reply to: OPC write value issue-IBH opc server #4684
    I suppose the URL here is the ID of the OPC server, e.g. Matrikon.OPC.Simulation/{f8582cf2-88fb-11d0-b850-00c0f0104305}
    in reply to: HTTPS on Linux #4683
    Please make a screenshot of the browser console (Press F12 in browser).
    in reply to: Schedule Export #4682
    Technically, report generation should be moved from the web app to a service. It requires redesign of the part of the internal structure of the source core.
    in reply to: Schedule Export #4681
    This function would be useful. We are ready to implement it as a part of commercial contract.
    in reply to: OPC write value issue-IBH opc server #4675
    Why you don’t pass valid URL to new OpcCom.Da20.Server(url, server)?
    This URL is needed to specify the server you connect.
    Why does not call a implementation of IServer instead?
    Interface is just a declaration. The runtime executes the method of an object that was actually created.
    in reply to: HTTPS on Linux #4674
    I think the only way at this time is written here. I mean using reverse proxy.
    in reply to: Generate Event using formula #4673
    1. This may be a heavy solution: create channels that indicate out of bounds and tick the checkbox to write events on change of these channels.
    2. Add generating events function to Automatic Control Module.
    3. Update Rapid SCADA mechanism of generating events. This is the best option.
    The 2nd and the 3rd items could be done on commercial basis faster. Or wait when we implement them for free.
    and assign thresholds to formulas that will change the status of your new notifications
    Yes, but changing status doesn’t generate events.
    in reply to: Change event sound #4672
    Is there any way to repeat the sound until event acknolegement?
    This feature requires development of a new plugin which does what you need.
    I replace the event.mp3 file but the original sound is playing simultanious with the new sound, any way to solve that?
    If you delete the old file, probably it was cached by a browser. Try clearing the browser cache.
    in reply to: Simulate a Modbus master and slaves communication #4665
    This video may be useful.
