Forum Home › Forums › Understanding the Software › Simulate a Modbus master and slaves communication
- This topic has 6 replies, 3 voices, and was last updated 7 years, 9 months ago by
November 24, 2018 at 6:56 pm #4649
catarinadf
ParticipantHello,
I am trying to simulate an ICS with the following characteristics:
– (PD6830-AX0-I-2) 1 Modbus scanner to monitor levels and temperature in tanks
– 4 Tank level gauges as slaves (MTS M-Series)
Unfortunately, I don’t know where to start. Should all the devices share the same communication line? What should be the configuration for a Modbus master-slave communication in RapidScada? What is exactly the device template editor and where can I get that information?Thanks.
November 25, 2018 at 7:40 am #4654
Please clarify, what are “4 Tank level gauges as slaves”? How do they connected and what protocol use?
I suggest this article http://doc.rapidscada.net/content/en/use-cases/modbus-protocol.html
The template editor is http://doc.rapidscada.net/content/en/use-cases/modbus-protocol-files/modbus_template_en.pngNovember 25, 2018 at 7:41 am #4655
MikhailModeratorI need a bit more info to help you.
November 26, 2018 at 11:17 am #4660catarinadf
ParticipantHello,
I have already looked at those 2 articles. But I still don’t understand since only one device is simulated with an existing device template.
I would like to simulate this ICS : https://www.predig.com/sites/default/files/images/Connections/6830X_FI_Modbus_RS-485_4Tanks-1_Detailed.jpg
How does the master and slaves communicate with the Modbus protocol in RapidScada ?Thanks.
November 26, 2018 at 12:57 pm #4661
manjey73ParticipantRapidScada communicates with Modbus devices as well as other programs. Through registers described in the DOCUMENTATION for the device. But through pictures alas no one not able to communicate. You need documentation for the device, the picture you showed.
November 26, 2018 at 4:36 pm #4664
MikhailModeratorRapid SCADA implements Modbus master to poll devices. If you need simulate a Modbus device, you should download an app like this. And then create a Modbus template according to the manual of your controller.
November 26, 2018 at 4:38 pm #4665
MikhailModeratorThis video may be useful.
