MikhailModeratorYou need an input channel that stores max. value of each day. Than use this channel in your report configuration file.
You need:
1. Add commands in your Modbus template.
2. Check that the commands work well in Communicator.
3. Create output channels in Administrator to send commands from Server and Webstation.
MikhailModeratorThe new formulas for moving (rolling) averaging are shared here. Thanks a lot to Horacio for sponsorship.
February 1, 2019 at 2:37 pm in reply to: Elastic Report and Chart Export function through iPad #4968
However, I am unable to click on the select-box for the formats ‘Excel’, ‘PDF’, ‘HTML’.
The old scripts may be cached. Can you clear browser cache on iPad?
January 31, 2019 at 2:58 pm in reply to: Elastic Report and Chart Export function through iPad #4964
MikhailModeratorreplace the first line of the fragment to
if (false && scada.utils.iOS())The features should be enabled on iPad. How do they work?
January 31, 2019 at 2:57 pm in reply to: Elastic Report and Chart Export function through iPad #4963
MikhailModeratorLet’s play with Elastic Report.
Open C:\SCADA\ScadaWeb\plugins\ElasticReport\js\elasticrep.js
Find the code:if (scada.utils.iOS()) { // disable Excel and PDF formats for iOS $("#rbHtmlFormat").prop("checked", true); $("#rbExcelFormat").prop("disabled", true); $("#divExcelFormat").addClass("disabled"); $("#rbPdfFormat").prop("disabled", true); $("#divPdfFormat").addClass("disabled"); } else { var format = localStorage.getItem(FORMAT_ITEM_NAME); // switch to stored format if (format == "PDF") { $("#rbPdfFormat").prop("checked", true); } else if (format == "HTML") { $("#rbHtmlFormat").prop("checked", true); } }January 31, 2019 at 2:55 pm in reply to: Elastic Report and Chart Export function through iPad #4962
Replace the newly bought iPads with Android tablets?
I would not like this way.
Minute Data report are functioning normally on the iPad.
This is interesting. My iPad can’t open Minute report. What application opens this report on your iPad?
Is it due to the licensing of Elastic Report and Chart Pro which limits the function on iPad?
Is there any way to enable these functions on the iPads?Only technical reason. The cause is that iPad has no internal location to save report files. May be this changed since the reports were developed. We should try to run them and see what happens.
MikhailModeratorCould you provide the info listed below?
1. Sequence of steps that reproduces the problem.
2. Expected result.
3. Actual result
You should not use MSSQL Compact from SCADA-Server. If you need access to the configuration database from SCADA-Server, explore the files in DAT format from C:\SCADA\BaseDAT
We will get rig of MSSQL Compact soon.
Export to Database Module already included. It’s path is C:\SCADA\ScadaServer\Mod\ModDBExport.dll
You need to add it to SCADA-Server on the Modules page and then configure using the scripts listed by this link.
MikhailModeratorI hope you can change the size.
For a big system, you may need our assistance to research how Rapid SCADA works under the required load and what the bottle necks are. Changing either data formats or internal protocol may be a subject of a contract between our companies. This is a business model of our project and many other open source projects.
MikhailModeratorBy default, it is in C:\SCADA\ScadaWeb\log\
MikhailModeratorI need send tens of thousands of bytes to ScadaServer
Could you describe your system?
MikhailModeratoris already used900M memory
Seems not usual. Do you use the default configuration?
