Send data from server to Device Modbus
Forum Home › Forums › Communicating with Devices › Modbus › Send data from server to Device Modbus
  • #4971
    scadarapid
    I am very newly. I use modbusrtu protocol connect to the Rapidscada. I can read the data from SCADA-Communucation, and I can send the data to the Server. The problem that I would like to ask you. How can we send the data from Server to device.
    thank you so much.
    #4972
    You need:
    1. Add commands in your Modbus template.
    2. Check that the commands work well in Communicator.
    3. Create output channels in Administrator to send commands from Server and Webstation.
