Viewing 15 posts - 3,601 through 3,615 (of 6,218 total)
  • in reply to: Chart auto refresh every 2s and store date every 1s #7095
    > some data are missing
    Likely the device didn’t respond that periods of time.
    > would you please explain more on how to use the rolling mode, and how to put chart on scheme using extended scheme components
    In the rolling mode, a period of the specified length is displayed on chart. For example, 30 last minutes.
    Using Scheme Editor, put a chart component on a scheme and set its properties as you need. Select fixed or rolling mode.
    in reply to: AllenBradley PLC Polling Driver (Ethernet) #7089
    Cool!
    Should I add the driver to the repository?
    in reply to: read modbus register as ASCII #7088
    In the formula you should join the strings. Something like
    string s = "";
    for (int cnlNum = 101; cnlNum < 110; cnlNum++)
      s += ScadaUtils.DecodeAscii(Val(cnlNum));
    return double.Parse(s)
    in reply to: read modbus register as ASCII #7087
    do you have suggestion for that, any tested formular?
    You should develop a formula by yourself. The idea is the following:
    1. Create an input channel of the calculated type.
    2. Add a formula in the Formulas table
    double MyFunc()
    // your code here
    3. Use this formula for the created input channel.
    in reply to: Chart auto refresh every 2s and store date every 1s #7086
    In addition to the above, configure Chart Pro by editing PlgChartPro.xml, and set the RefreshRate parameter. I suggest use Chart Pro in the rolling mode if you need to refresh it often. To do this, use Dashboard Plugin, or put a chart on a scheme usgin Extended Scheme components.
    in reply to: write event trigger #7077
    It’s not supported.
    To do this, it can be a good idea to use Automatic Control Module which has to be upgraded for event generation.
    in reply to: Download configuration remotelly #7072
    May be we should change the size from 10485760 to 104857600 by default.
    in reply to: Download configuration remotelly #7071
    It means that the configuration is too big (more than 10 MB). When configuration is transferred, it is zipped to reduce size. So 10 MB is a size of an archive.
    There are 2 options how to fix:
    1. Check your interface files. May be you should optimize images.
    2. Increase maxReceivedMessageSize in C:\SCADA\ScadaAdmin\ScadaAdmin.exe.config
    • This reply was modified 5 years, 8 months ago by Mikhail.
    in reply to: read modbus register as ASCII #7068
    1. Read the registers from 30215 to 30218 as a double (8 bytes) in Communicator. They will be passed to a one input channel.
    2. Check the displayed value.
    Share new screenshots, please.
    in reply to: Chart Pro does not show charts #7067
    Hello Irene,
    It looks like the configuration file of Chart Pro is not included in the project. Please find PlgChartPro.xml in the distributive package of Chart Pro and copy it to YourProject\Instances\Default\ScadaWeb\config\ directory.
    Then upload the project to the server.
    in reply to: ChartPro – Excel Export Option #7066
    Chart Pro supports export channel values to Excel.
    in reply to: Download configuration remotelly #7057
    The additional error information is in C:\SCADA\ScadaAdmin\Log\ScadaAdmin.err
    Please provide the error details from the log.
    in reply to: Variable limits in extra scheme components #7054
    Min and Max are constants. That’s true. As a work around you could create an extra input channel of the Calculated type. And set a formula to calculate some kind of relational value.
    i would like the right picture, but the colors of the ring changing with time regarding a variable bandwidth.
    The right picture uses a background found somewhere in the internet. A display over a gauge is a dynamic text component.
    in reply to: Toggle color #7052
    The values in the table, also black, not red and green. This means that input channels are not configured properly. You should also set the Unit field to Off-On.
    in reply to: Try to integrate with IED using DNP3 Protocol #7050
    Please contact us by email for more info.
