MikhailModeratorI wonder if it was caused by ccleaner or AVG. Likely the last one.
December 24, 2020 at 2:24 pm in reply to: Launch external code editor and/or store project code in cs file #7836
MikhailModerator3rd possible method (based on your idea):
Imagine you have a project containing formulas like https://github.com/RapidScada/scada-community/tree/master/FormulasThe Admin app would support extensions (separate DLLs) that allow adding custom features to the Admin app. We will develop an extension that extract content of a project class and inserts it in the configuration database right before uploading or by button click.
What do you think?
December 24, 2020 at 2:20 pm in reply to: Launch external code editor and/or store project code in cs file #7835
MikhailModeratorformula code can be easily tested in IDE by user.
These small files would not be correct C# files, because in C# everything must be inside a class, but Rapid SCADA formulas must contains only properties and methods without class definition.
December 24, 2020 at 2:11 pm in reply to: Launch external code editor and/or store project code in cs file #7833
MikhailModeratorThank you for paying attention to this question.
To develop complex formulas I prefer using VS like here.
I will think how to simplify editing formulas without VS.December 24, 2020 at 2:01 pm in reply to: Elastic Report: Reports on different Views other then Main View/Reports #7824
Currently, using links is the only way to display reports among views.
MikhailModeratorSettings and logs look good.
Trigger is written in ModAutoControl.log when a channel changes. If you stop Communicator and the restart only Server, I expect no triggers in ModAutoControl.log
Please do the following:
1. Stop the Communicator service.
2. Set different values for the channels 7239 and 7240 using the Generator function in Administrator. What are the results?
MikhailModeratorThanks a lot!
MikhailModeratorSo, sounds like if I set the channel to a special null archive,
like /dev/null in linux, that channel’s logging is disabled.I think, this is different.
MikhailModeratorCnlVal contains value that is received from controller.
Val() is a function that retrieves current channel value. Channel values are loaded on start.
Thank you for the screenshots.
Please check the following:
1. Is there the trigger for 7239 in ModAutoControl.xml that is located in C:\SCADA\ScadaServer\Config?
2. Is there any mention of the trigger name in C:\SCADA\ScadaServer\Log\ModAutoControl.log ?What are the versions of SCADA-Server and ModAutoControl.dll?
MikhailModeratorYou could create a property like
double MyVar { get { return Val(101); } set { SetVal(101, value); } }Where 101 is the input channel number. Channel of the calculated real type. Note: I didn’t tested it.
MikhailModeratorDo you think this would cause a problem in communication?
It is highly possible. If I were you, I would connect another converter instead of PLC and check if data are received from the 1st converter.
If your converter has more than 1 RS-485 port, you can perform this test using the single converter.
This feature will be supported in the next generation Rapid SCADA 6. It will be possible to choose for a channel, which archives it is written to.
I saw there is a command type named REQUEST.
By sending the command of the Request type you can perform a device poll out of turn. It is useful when there are many devices and an operator wants to poll a device immediately.
To save and load values you can store them into input channels. Current values of input channels are loaded on start.
Otherwise, it’s better to develop a Server module and store values in a file.
MikhailModeratorWill create a release. Thanks.
