Viewing 15 posts - 2,806 through 2,820 (of 6,219 total)
  • in reply to: Send command with button #9383
    Screenshot of the input channel can be useful
    in reply to: Send command with button #9382
    The settings look OK. Check in ScadaServer.log that commands are received by the server app.
    in reply to: Scheme copy #9378
    except the content in the frame can not be loaded even for long long time
    Open browser tools by pressing F12 and check why the frame content is not loaded.
    Screenshots can help to find the cause.
    We will waiting for your next version to try.
    The issue is not related to a version.
    in reply to: Detect server restart when using the tcp socket api #9372
    Using Rapid SCADA client you can get file age of incnl.dat file. It is changed when configuration is uploaded.
    ServerComm.ReceiveFileAge() method
    in reply to: Disable password request on command #9371
    Yes.
    in reply to: Scheme copy #9370
    During installation for extra components, I have not meet “registration key”.
    Where to get it?
    After activating the plugin, look in Main Menu – Registration in Webstation
    in reply to: Scheme copy #9354
    Another method:
    Hold the Ctrl button and click the components to multiple select.
    Press Ctrl+C to copy components to the clipboard.
    Then choose Edit – Paste Special to paste components.
    Scheme Templates also good, but using many frames may affect performance.
    in reply to: opc da do not work #9352
    OPC DA is a black box. I strongly recommend to move to OPC UA because it is more reliable, and .NET5 and higher will not support classic OPC.
    I can provide the source code of the driver if needed.
    Also try this advice.
    in reply to: scheme loading failed. Try to reload scheme #9351
    The answer is here.
    in reply to: Database SQL usage #9325
    5.8.3
    I think, 5.8.2. If needed, it the module can be updated to be compatible with 5.8.3.
    • This reply was modified 4 years, 8 months ago by Mikhail.
    in reply to: ScadaAdmin.exe can not be started #9323
    This error message means that ScadaAgent does not open TCP port 10002. Check agent configuration and log file.
    in reply to: ScadaAdmin.exe can not be started #9320
    Make sure that the Temp subdirectory exists.
    If it doesn’t help, provide error details from ScadaAdmin.err
    in reply to: sevice start fail for built version 5.8.3 #9314
    the service can be installed, after stop virus-killer software.
    Which antivirus software?
    in reply to: Export data module manual exist? #9313
    All docs were moved to web. Link
    in reply to: Installation failure #9308
    The user interface is very close between 5.7 and 5.8. You should use the latest version of Rapid SCADA.
