opc da do not work
Forum Home › Forums › Communicating with Devices › OPC › opc da do not work
  • #9341
    Zeus
    I got a problem to communicate with OPC DA Server.
    https://ibb.co/Z2jN5KG
    it stops communicating with the server after add tags.
    How can i debug it?
    #9352
    OPC DA is a black box. I strongly recommend to move to OPC UA because it is more reliable, and .NET5 and higher will not support classic OPC.
    I can provide the source code of the driver if needed.
    Also try this advice.
    #9358
    Zeus
    It works. Thanks!
