MikhailModeratorTo reduce the list of combinations, describe what result do you need.
For some reason, channel generation for MQTT client has not been implemented yet.
You should create channels manually. Copy channel properties from Simulator channels.
Thank you for reporting this issue.We will implement the feature for MQTT channel generation with a priority, and I will let you know about it in this topic.
MikhailModeratorThe app started at 19:33, but errors occurred at 15:18. Therefore, they don’t matter.
MikhailModeratorAdd a led component to a scheme, and set its Input channel property to the particular channel.
MikhailModeratorUnits are displayed on schemes, and not displayed in table views.
MikhailModeratorI see that there is “average” column inside the input channel description table? May I know what is the meaning of average here?
See the example.
MikhailModeratorWe can directly type formulas in that xml file or we have to do calculations only in excel after exporting?
You can insert formulas in the XML. ElasticRepExample.xml contains an example:
<Column name="Summary Consumption" calcType="Formula" value="=SUM(RC[-3]:RC[-2])" calcTotal="true" colStyle="col-lg" />
MikhailModeratorTo check the settings, you should provide screenshots of the settings.
MikhailModeratorIf a trial key is expired, you can get a new daily trial key for free.
MikhailModerator
MikhailModeratorTable views and events can be exported to Excel out of the box. It’s free.
MikhailModeratorClick the Refresh data button above the edited table.
MikhailModerator
Yes. In Administrator open your project, open ScadaWebConfig.xml and set ShowMainMenu to false. Then upload the project.
MikhailModeratorTo display only current data, use schemes instead of table views.
