Viewing 15 posts - 2,221 through 2,235 (of 6,243 total)
  • in reply to: Dashboard plug in #11362
    Could not open the link above. Please check.
    in reply to: Input and Output Channels #11361
    In the device template, a user enters tags of device. Channels should be created by the channel wizard.
    in reply to: How to configure Archive? #11360
    The archiving interval, configurable target archive for channels are all long wished features.
    These features required a lot of work. We try to listen our users. However, implementation can take a long time.
    in reply to: How to configure Archive? #11359
    There is this Archive Kind table, not sure what to set in there.
    If it’s empty, download the latest update and take this table from the Administrator’s template.
    Could you provide screenshots? Probably, you need some update.
    Device status can be bound to a channel.
    Set the channel’s tag code to Status
    It is possible to start and stop communication lines using commands from Server.
    The following tag codes are supported:
    App.Comm.StartLine
    App.Comm.StopLine
    App.Comm.RestartLine
    App.Comm.StartAllLines
    App.Comm.StopAllLines
    App.Comm.PollDevice
    Command value may contain line number or device number if needed.
    Tag codes are listed here.
    in reply to: Calc value from multiple device #11357
    It’s possible, but more tricky. Check the averaging formulas.
    The only way to get the server to accept it is to delete certain conditions but it still doesn’t work,
    The formula suggested above differs from the formula you posted. Try the original one. In case of errors, provide the error information.
    in reply to: Rapid SCADA 6 Beta #11331
    Did you tested it on iPhone and Android, both?
    If you do a pull request to the scada-v6 repository, I would keep it open for possible future use.
    in reply to: Tooltip on mobile browser #11330
    I’m not sure that Bootstrap is a good choice for schemes, because it is may be too heavy for schemes that contains thousands components.
    in reply to: Data History #11329
    I suggest to install Rapid SCADA 6 Beta and use it with conjunction with InfluxDB. There are the options to store data as fast as possible.
    in reply to: Rapid SCADA 6 Beta #11325
    What modifications are needed for PWA?
    in reply to: Tooltip on mobile browser #11324
    Thank you. Will check it later when work on schemes.
    in reply to: Calc value from multiple device #11323
    Formula of the channel 532 refers itself.
    in reply to: Rapid SCADA 6 Beta #11318
    It’s good if you can create a simple example web plugin in the community repository for us
    One of the planned plugins is a Module Repository Plugin. When this plugin will be created, it can be a good simple example.
    About PWA, I’ll push my local changes to github
    Is it possible to pull it to scada-community repository? I would merge it there.
    in reply to: Notification plug in (trial key vs paid registration key) #11317
    I’ve written this idea to be implemented in version 6. Thank you.
