November 18, 2022 at 11:40 am in reply to: Export channel data to excel for longer periode of time #11578
A period limit can be configured in Rapid SCADA 6.
Yes it’s possible. The method depends on the operating system.
In case of an error, please provide the error message.
See checkLoggedOn
MikhailModeratorif modules permanent key purchased are valid for V6
We upgrade keys manually for free for the same machine.
MikhailModeratori just need that autologin can be possible only from localhost
Probably you should deploy 2 instances of Webstation with different settings.
MikhailModeratorCould you explain?
MikhailModeratorThanks to kumajaya and zzz
In general, you are on the right way.
“Not available” status is OK. That means that the Webstation app does not support providing status.
After restart, some time is needed to be able to login.
If after 10 seconds you can’t login, check the Webstation log in the Administrator app for errors.
MikhailModeratorMy complain is that current administrator doesn’t work on Linux natively.
Agree with that. @kumajaya runs ScadaAdmin on Linux using Wine.
Thank you for the feedback.
MikhailModeratorI think, the above idea with MQTT is the best.
Also it’s possible to connect to Agents and get instance statuses. Agent can establish reverse connection with the main Agent that provides single point to get data.
Do the configuration of Communicator and Webstation applications transfer correctly?
Table views do not contain custom images. Logo can be added to schemes.
Set the undefined channel status if value is 65535 with a formula.
MikhailModeratorJust try those properties.
