Viewing 15 posts - 1,576 through 1,590 (of 6,239 total)
  • in reply to: OPC DA to UA Gateway #13047
    Answer is here. Additional configuration is not necessary.
    in reply to: OPC UA Server #13046
    You can find the URL in Logs, DrvDsOpcUaServer_*.log
    For example, opc.tcp://mycomp:62541/RapidScada/DrvDsOpcUaServer
    in reply to: Additional calculation triggering #13045
    You can find file formats here. The source code also available. If you need getting data directly from archives, I suggest using PostgreSQL or InfluxDB archives.
    in reply to: can’t connect to server #13044
    SCADA-Server uses port 10000 by default.
    When The application is not ready. Try again later. is displayed, the details are written in the log file. Did you configure RAM disk for logs? Try to find logs directly on the disk.
    • This reply was modified 2 years, 9 months ago by Mikhail.
    in reply to: OPC DA (Classic) on RPI #13031
    No, because OPC DA is a Windows technology only.
    You can install SCADA-Communicator (and Agent) on Windows machine and interact with it from RPi.
    in reply to: rapidscada 6.1 install on linux problem #13030
    Yes, staging branch is important. I don’t know what is implemented in the staging branch that makes the app work.
    You should put the files listed in the errors. ScadaAdmin_Wine.zip contains only executable file, but the Administrator app needs other files which should be taken from the installation package.
    in reply to: Copy and paste notifications #13025
    Please provide screenshots of the module settings and the module log.
    in reply to: How to set up Telegram #13023
    If the last question is about Automatic Control Module, please ask in a proper topic. This topic is about Telegram driver.
    in reply to: No Communication now #13021
    As a result you should be able to open a TCP connection to IP 172.40.0.10 port 502 by any application: Communicator, Hercules, Telnet, etc.
    in reply to: No Communication now #13020
    It’s a network issue. Ping uses another protocol than TCP.
    You should check a network configuration. Something like this.
    in reply to: No Communication now #13018
    Looks like 172.40.0.10:502 is not available from the VM.
    You could also download Hercules utility and try to connect by TCP client. I expect that result will be similar.
    in reply to: No Communication now #13015
    Should the virtual machine have an IP address within the same range of the physical meter to establish communication?
    This is not obligatory, and depends on the router settings. Could you copy a part of communication line log? Ctrl + C works in the Administrator app.
    in reply to: rapidscada 6.1 install on linux problem #13014
    ScadaAdmin for Wine is here. May be it’s not the latest, anyway it should start.
    1. Install Wine according to https://wiki.winehq.org/Ubuntu
    winehq-staging is needed
    2. Run winecfg
    3. Check Wine version wine --version
    4. Change directory to the app directory. Run wine ScadaAdmin.exe
    5. Check ScadaAdmin logs in /home/myuser/.wine/drive_c/users/myuser/AppData/Local/
    Does it work?
    in reply to: rapidscada 6.1 install on linux problem #13011
    If you need to run Admin with Wine, ask for special instructions.
