OPC DA (Classic) on RPI
  • #13029
    sperate
    Hi, Is it possible to read from and write to OPC DA server with Rapid SCADA running on Raspberry Pi ?
    #13031
    No, because OPC DA is a Windows technology only.
    You can install SCADA-Communicator (and Agent) on Windows machine and interact with it from RPi.
    • This reply was modified 3 years, 1 month ago by Mikhail.
    #13051
    sperate
    However, I’ve learned that is it possible to install windows 10 for ARM on RPI nowadays !
    https://worproject.com/
    #13056
    If you do, please share your experience.
    #13057
    I expect that you need OPC libraries built for ARM in this case. Not sure they exist.
    #13063
    I strongly doubt that there will be DCOM support in the Windows 10 version for ARM
