LPG57
ParticipantIs there a manual how to “create a PostgreSQL database and specified it in ScadaInstanceConfig.xml”
LPG57
ParticipantI get the following error when I try to login with a domain account:
2025-02-01 16:06:07 [SERVER8][SERVER8$][ERR] Module ModActiveDirectory: Error updating user information in database:
Failed to connect to 127.0.0.1:5432
2025-02-01 16:06:07 [SERVER8][SERVER8$][ERR] Checking username and password for user myusername is not successful: Error updating user information in database
2025-02-01 16:06:11 [SERVER8][SERVER8$][ERR] Module ModActiveDirectory: Error updating user information in database:
2025-02-01 16:06:11 [SERVER8][SERVER8$][ERR] Checking username and password for user myusername is not successful: Error updating user information in databaseIs there a need for security groups in AD like in older versions of RapiScada?
LPG57
ParticipantFound that it worked when doing an upload instead. Can you please describe when to use upload and when to use download?
But now when trying to login, I get: “Please correct the following errors: Error updating user information in database”
LPG57
ParticipantI activated the ModActiveDirectory module, filled in IP of the DC and “mydomain.local” in the search root. I the saved and downloaded. But when open modules again, the ModActiveDirectory module was back in the unused modules pane. I have tried several times with the same result.
December 27, 2024 at 9:47 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15851LPG57
ParticipantI reinstalled Rapid Scada and tried again, and now it works. Seems like I got some database mismatch, I also got data from the example project in the line I had working.
December 26, 2024 at 10:43 am in reply to: Unable to communicate with the device [4] TestDev because connection is not est #15847LPG57
Participant2024-12-25 20:52:33 Start communication line [4] TestLine
Load device template from file DrvModbus_TestLine.xml2024-12-25 20:52:33 Unable to communicate with the device [4] TestDev because connection is not established
2024-12-25 21:38:58 Communication line [4] TestLine is stopped
——————————————————————————–LPG57
ParticipantI installed version 5.5.3 instead and it worked.
LPG57
ParticipantThanks’! Sometimes it is the easy things…
LPG57
ParticipantThis issue is solved after your instructions above. Automatic Command tested and working!
Thank You!
LPG57
ParticipantA new problem: when trying to save the commands, I get the following error:
http://www.granberg.tv/Capture3.PNGLPG57
ParticipantYes, the solution in link 1 worked, copied the file to the desktop, unblocked it and copied it back.
BTW, how is the Computer code generated (for purchasing the license)?
LPG57
ParticipantYou are right – my mistake.
LPG57
ParticipantYes, I copied the dll to this folder.
LPG57
ParticipantMikhail,
I’m having the same trouble as mentioned above. I tried with unblocking the dll, but it didn’t help. -
