hethongscada62
ParticipantDear Mr. Mikhail,
I am using a Rapid Scada 5.
Han Hoanghethongscada62
Sending email from directly from email device and via Auto control module have been tested on Windows. All they are working fine. But they are not work on RPi (Of course after installing Auto control plugin and configure a email driver) . So could you let me know: Which files (Auto control plugin and email driver) on Windows I have copy then past to RPi?
Thanks and best regards
ParticipantHi Victor,
Noted that you have to Check the settings:
https://ibb.co/hKd7VfT
The best regards
ParticipantHello Victor,
Please follow the all steps that Mr. Mikhail gave in instructions. Means to create an email mailbox in Yandex, then set up the properties of the email device as follows
https://imgbb.su/image/xuFrpn
And setup an Address book as instruction.
Have a good result
Thank you for your reply,
After checking the date version, reboot a RPi. The status of device that seems is normal, but after refreshing RPi, the status of device is error.
https://imgbb.su/image/xgEHFw
https://imgbb.su/image/xgEbQc
https://imgbb.su/image/xgE3IQ
https://imgbb.su/image/xgENDl
Where is wrong?
Thanks a lot
The Email driver have been installed in Windows for testing. It works perfectly when I send email directly via command of device. Then this Email driver installed in Raspberry Pi4.
https://imgbb.su/image/xJK1V6
It not works via Automatic Control module.
https://imgbb.su/image/xJKrDE
https://imgbb.su/image/xJKPhS
May be the configure of Automatic control is wrong, isn’t?
https://imgbb.su/image/xJT4VC
Could you check and let me know.
Thanks a lot
Sorry I wasted your much time
Thank you for your repply. I will test it with Unreal Media server
Thanks again.
I am interested in your configure
https://rapidscada.org/wp-content/uploads/projects/kaz/kaz02.png
I have been reading this topic in Russian but did not understand.
Which camera model do you use? Can the IP Yoosee camera use?
Could you show me a step-by-step to configure it?
Dashboard plugin was installing on my project. It is running well except <Widget type=”CustomUrl” url=”https://www.youtube.com/embed/xs8Tqkr-Gn4″ />. There was note on Screen “This video is unavailable”
https://imgbb.su/image/x9Nc7w
Some questions are here:
1) How to configure Widget type=”CustomUrl”? Could you show me step by step to do it?
2) Can use Widget type=”CustomUrl” to display livestreams from IP Camera? If it can how to configure it?
Thank You for your repply.
How will I get a Raspberry Pi4 code for purchase Key?
My project is running on Webstation V5.1.0.0. Did you test a Huawei e1750 with V5.1.0.0?
ParticipantDear Mr.Mikhail,
I am using the version Webstation 5.1.0.0 so which telegram plugin will be suitable? I am going to buy telegram plugin so Pls let me know how to get a Raspberry Pi4 code?
My project Rapid Scada is running on Raspberry Pi4, so could let me know how to install a Telegram plugin on Raspberry Pi?
ParticipantDear Mr.Mikhail.
Modem Siemens C35 is difficult to get it in my country. Huawei likes E173x is popular. Dcom USB 3g Huawei is connecting to test. Using this modem to send SMS on computer it works perfectly. Testing to send SMS via Rapid Scada It not worked. Fault is the same.
https://ibb.co/xJwrKgr
https://ibb.co/LvpKqqH
Where is wrong?
Thank You again.
Thank You for your repply. Maybe I will use another modem.
Thank you again.
Han Hoang -
