ali_amiri
ParticipantHi Mikhail,
in the log file I have this error:2020-11-11 23:50:56 <raspberrypi><pi><ACT> Initialize common data of Scheme Editor
2020-11-11 23:50:56 <raspberrypi><pi><ACT> Load components from files
2020-11-11 23:50:57 <raspberrypi><pi><ACT> Components are loaded from the file /opt/scada/ScadaWeb/bin/PlgSchBasicComp.dll
2020-11-11 23:50:58 <raspberrypi><pi><ACT> WCF service is started
2020-11-11 23:50:58 <raspberrypi><pi><EXC> Error opening browser:
System.ComponentModel.Win32Exception (0x80004005): Cannot find the specified file
at System.Diagnostics.Process.StartWithShellExecuteEx (System.Diagnostics.ProcessStartInfo startInfo) [0x00102] in <3d97dda773a54430b892e1d794e5d921>:0
at System.Diagnostics.Process.Start () [0x00032] in <3d97dda773a54430b892e1d794e5d921>:0
at (wrapper remoting-invoke-with-check) System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start (System.Diagnostics.ProcessStartInfo startInfo) [0x0001b] in <3d97dda773a54430b892e1d794e5d921>:0
at System.Diagnostics.Process.Start (System.String fileName) [0x00006] in <3d97dda773a54430b892e1d794e5d921>:0
at Scada.Scheme.Editor.FrmMain.OpenBrowser () [0x00070] in <1d900a6189354913afd7c5168087559a>:0ali_amiri
ParticipantNow I receive both device data correctly in the “scada-communicator”.
but I can not show devices value on the “webstation”
only one of devices value is shown.ali_amiri
can you explain more?
I could not solve the problem.
If you need more information please tell me.ali_amiri
Participanthttps://www.dropbox.com/s/twp9oumw9d8k6hd/Capture01.JPG?dl=0
https://www.dropbox.com/s/s5tmmnhl7i8wef5/Capture02.JPG?dl=0
https://www.dropbox.com/s/w1gl1h8qwv7v65a/Capture03.JPG?dl=0
https://www.dropbox.com/s/p3xcggw7zowyj3r/Capture04.JPG?dl=0
https://www.dropbox.com/s/hes3ubdoux4pvmh/Capture05.JPG?dl=0
https://www.dropbox.com/s/6hazlpb1k02yfkf/Capture06.JPG?dl=0ali_amiri
ParticipantHi Manjey73,
I don’t understand.Please explain more.
please look at these pictures:
July 17, 2017 at 11:09 am in reply to: Login to software with cell-phone browser or another PC #2375ali_amiri
ParticipantHi all,
I opened World wide web service (Port : 80) on the server and now I can connect from another device.
Thanks a lot.July 16, 2017 at 11:05 am in reply to: Login to software with cell-phone browser or another PC #2366ali_amiri
My problem is Ethernet.when I enter this URL “IP/scada” in my another PC on the same network, nothing showed.
my server IP is: 192.168.1.101
my other PC IP: 192.168.1.112
I put “192.168.1.101/scada” in my other PC browser but nothing is showed.
How can I test Server PC ?
Tnx -
