2020-11-11 23:50:56 <raspberrypi><pi><ACT> Initialize common data of Scheme Editor
2020-11-11 23:50:56 <raspberrypi><pi><ACT> Load components from files
2020-11-11 23:50:57 <raspberrypi><pi><ACT> Components are loaded from the file /opt/scada/ScadaWeb/bin/PlgSchBasicComp.dll
2020-11-11 23:50:58 <raspberrypi><pi><ACT> WCF service is started
2020-11-11 23:50:58 <raspberrypi><pi><EXC> Error opening browser:
System.ComponentModel.Win32Exception (0x80004005): Cannot find the specified file
at System.Diagnostics.Process.StartWithShellExecuteEx (System.Diagnostics.ProcessStartInfo startInfo) [0x00102] in <3d97dda773a54430b892e1d794e5d921>:0
at System.Diagnostics.Process.Start () [0x00032] in <3d97dda773a54430b892e1d794e5d921>:0
at (wrapper remoting-invoke-with-check) System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start (System.Diagnostics.ProcessStartInfo startInfo) [0x0001b] in <3d97dda773a54430b892e1d794e5d921>:0
at System.Diagnostics.Process.Start (System.String fileName) [0x00006] in <3d97dda773a54430b892e1d794e5d921>:0
at Scada.Scheme.Editor.FrmMain.OpenBrowser () [0x00070] in <1d900a6189354913afd7c5168087559a>:0
