josef.novotny
  • in reply to: OPC UA Driver #9578
    josef.novotny
    Hello, with new driver working everythink OK.
    Super.
    Thak you veru much, Josef.
    in reply to: OPC UA Driver #9560
    josef.novotny
    Hi, today i update Rapid Scada from scada_5.8.1_full_en to scada_5.8.3_full_en.
    KpOpcUa.dll… 5.0.0.1
    But problem is the same as previos post.
    Thanks for your reply, Josef
    in reply to: OPC UA Driver #9559
    josef.novotny
    Hy, driver version is…
    KpOpcUa.dll… 5.0.0.0
    Opc.Ua.Client.dll… 1.4.356.27
    Opc.Ua.Configuration.dll… 1.4.356.27
    Opc.Ua.Core.dll… 1.4.356.27
    Screenshots, and XML setting are here.
    in reply to: OPC UA Driver #9554
    josef.novotny
    Hi i try added new OPC UA device.
    Server browse connect OK to new OPC UA device with this security options…
    Security mode – None
    Security policy – None
    Authentication mode – Username and password
    Username – myusername
    Password – mypassword
    Save configuration, upload config to server, but in line state is Error.
    I check again security options in device properties.
    Username is lost.
    Why?
    in reply to: Help witch formula #6795
    josef.novotny
    Thank you very much too.
    in reply to: Output control by Input #6124
    josef.novotny
    I found this and other answer to my question.
    I can try demo Automatic Control Module.
    I download last version Automatic Control Module, when I wanted to start with the configuration, I found a this problem with Automatic Control Module.
    Now everything works OK.
    When I really try the automatic control module, I buy it for our smart home use.
    Thank you for everything, the Rapid Scada is a great nice project.
    Josef
    in reply to: Output control by Input #6119
    josef.novotny
    Hi, two different devices…
    First PLC device via OPC server as INPUT CHANNEL.
    New screen shot with all input channels HERE.
    Second device is ModBUS TCP device as OUTPUT CHANNEL (and INPUT channels to check the status).
    New screen shot with all output channels HERE.
    Screen shot from table editor here.
    Screen shot from web GUI Rapid Scada here.
    I reguire very simple function…
    When OPC input change state to 0 >>> change MODBUS output 2201 to 0
    When OPC input change state to 1 >>> change MODBUS output 2201 to 1
    In web GUI Rapid scada i see change state on input channel from OPC OK, but not work this change in output channel 2201. Why?
    When i set manual via small racket, in web GUI Rapid Scada table… function OK. MODBUS device change status on relay to ON, or OFF according to manual input.
    I check state MODBUS device every 5 seconds for read atual state relayes. Check state OK.
    When i change state to on or off via small rocket, i see some incorrects in log, but relay on ModBUS device change state to on or off OK.
    When change input channel from OPC server, i didnt see anythink.
    Josef
    in reply to: Output control by Input #6110
    josef.novotny
    in reply to: Chart – samples on the timeline #4363
    josef.novotny
    Excuse me: I want to see 5 seconds samples on the time-line in charts, how to do it ?
    in reply to: Hysteresis on input channel… #4336
    josef.novotny
    When i created new folmula by manjey73.
    Then I `apply and restart scada service.
    Scada server not running.
    In log…
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> ScadaServerService 5.1.0.4 is started
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Module is loaded from the file C:\SCADA\ScadaServer\Mod\ModAutoControl.dll
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Module is loaded from the file C:\SCADA\ScadaServer\Mod\ModDBExport.dll
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 114
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Ouput channels are read from the configuration database
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Users are read from the configuration database
    2018-10-04 00:27:46 <WRK-SCADA-V01><SYSTEM><ACT> Formulas are read from the configuration database
    2018-10-04 00:27:47 <WRK-SCADA-V01><SYSTEM><ERR> Error compiling the source code of the formulas:
    Line 543, column 14: error CS0103: The name Ticks does not exist in the current context.
    Line 548, column 16: error CS0103: The name Ticks does not exist in the current context.
    2018-10-04 00:27:47 <WRK-SCADA-V01><SYSTEM><ERR> Normal program execution is impossible.
    After delete new “Tof” formula. All ok again.
    in reply to: if variable change value every minute so 1 , otherwise 0 #2362
    josef.novotny
    Hi Mikhail,
    How much would it cost to purchase a development of the funkcions ?
    Josef
