Automatic control module installation error
Forum Home › Forums › Installation Issues › Automatic control module installation error
  • #5783
    dineshkumargowd
    Dear Mikhail,
    I would like to test the automatic control module, so installed the module. But following error was showing in the sever.
    Error getting module interface type from the library ModAutoControl.dll: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
    Version of Administrator was 5.5.0, scada server was 5.1.2.0, communicator was 5.2.0
    #5784
    You should rightclick the ModAutoControl.dll and unblock it.
    #5789
    dineshkumargowd
    Dear Mikhail,
    Right click was not able to do. I have activated it, but showing the error as stated earlier.
    #5790
    Rightclick the dll file in Windows explorer. I suppose, it is alwasys possible.
    #5808
    dineshkumargowd
    Dear Mikhail,
    It was unblocked successfully in windows explorer and i was able to use it.
    Thanks for your support.
