Viewing 15 posts - 721 through 735 (of 981 total)
  • in reply to: about module rapid gate #8070
    InCmdTransferOptions Options that determine receiving telecontrol commands from a remote server
    OutCmdTransferOptions Options that determine transferring telecontrol commands to a remote server
    Is this it ?
    in reply to: ScadaAdmin on Linux #8068
    Does the client have all the PCs on Linux on the local network ? You can connect via TeamViewer to any PC on the network and download the project from it, as well as control its work. Why does the Scada server also need a graphical shell, if we are talking about Linux, although you can run TeamViewer in it or just use SSH. The scripts are located in the Communicator and Server folders, as well as in the scadaagent folder if there is a need to overload any of the components. Don’t forget to give them execution rights.
    in reply to: ScadaAdmin on Linux #8061
    You can link one way or another if you have at least one public IP. There is no other way. Even the MQTT server requires a public IP to be able to forward data from one subscriber to another.
    in reply to: Get data from excel into DAT files #8057
    For some reason, the English site does not have this section or it is located in another place.
    https://rapidscada.ru/integration-with-rapid-scada/
    Use an online translator. Perhaps this will help you solve the problem of writing data from exel to Scada databases.
    • This reply was modified 5 years, 9 months ago by manjey73.
    in reply to: Internal server error (500) #8053
    run Web on https
    Read this topic and check how Apache is configured on a remote server, if in https mode you will have to do it by analogy for xsp4 or nginx
    in reply to: Write multiple modbus register FC=16 #8050
    Some devices may not respond if no ID is specified, even over TCP
    in reply to: Internal server error (500) #8045
    https or not to https, that is the question?
    in reply to: Get data from excel into DAT files #8041
    If you create the parameter in the same way as you checked this example, the file will be created ? If yes, try using the API
    in reply to: Write multiple modbus register FC=16 #8040
    00 Unit identifier 0x00 (0)
    Specify in the database, in addition to the IP address, also the address for the RTU mode, if the device has the ability to poll on the 485 interface or just 1
    in reply to: Get data from excel into DAT files #8029
    Mikhail promised to implement this in the next version of Scada. Now you can try using Grafana for these purposes
    in reply to: Get data from excel into DAT files #8022
    Status write “2”
    in reply to: Entering Data Into A Table #8006
    https://imgbb.com/upload
    BB-Code full and paste IMG
    in reply to: ScadaAdmin on Linux #8003
    I installed rapidscada on a Debian 10 VPS server with a public IP address
    Some remote objects are also connected to this server with the installed Communicator via 4G networks
    On the server, raise l2tp/IPsec
    packages – strongswan (ipsec) and xl2tp
    The remote communicator transmits data to the Scada server and at the same time has an IP address in the VPN network. By connecting to the server as an l2tp client from a Windows PC you can access remote communicators both via SSH and to download projects
    I use a Raspberry Pi (Zero) for remote Communicators and can prepare an image with version 5.8.2 by spending a little time over the weekend deleting my server’s keys and passwords. Would you be interested ?
    in reply to: Entering Data Into A Table #7983
    output channel – SetVal(43,Cmd)
    input channel 43 – Val(43) and in table “output channel” set 43, channel is Calculated
    in reply to: Transfer File from Computer to Rpi #7928
    Only for the initial installation and migration of driver libraries, for example. Edit the Instance name and key for the Agent. Otherwise, the project is transferred using the Agent from Windows to Linux without problems.
    WinSCP and SSH connection are enough to copy and install files.
