Rapid Scada hardware compatibility question
Forum Home › Forums › Uncategorized Issues › Rapid Scada hardware compatibility question
  • #6413
    kola_ohsir
    dear forum dwellers,
    for an upcoming project i need to install Rapid Scada on a machine with the following specs:
    CPU:
    Intel Celeron N3350, 1.1 GHz (2.4Ghz Turbo Boost)
    RAM:
    DDR3L, 4GB
    Input Voltage:
    12..24V
    Misc:
    compatible with Windows 10, 64bit;
    the project will include incoming 300 tags from S1500 controller.
    my question is: is this machine capable of running Rapid Scada, or do i need a better CPU for the job?
    thank you in advance!
    #6414
    RapidScada can run on a Raspberry Pi and its characteristics are somewhat more modest than you have shown.
    #6417
    If Windows itself works fast enough, it will be OK for Rapid SCADA.
