Viewing 15 posts - 676 through 690 (of 981 total)
  • in reply to: event triger #8928
    The same garbage for two events, the formulas seem to affect the creation of duplicates.
    in reply to: scheme editor #8927
    On the current version and earlier, you can save data every second, you need to change it manually in one of the configuration files.
    in reply to: scheme editor #8905
    Would you share the IEC104 driver ?
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8904
    It is necessary to look at the mono version, sometimes in the repositories the version is much younger than is required for Scada to work. Therefore, it is better to install Mono from the developers ‘ site. In the text document, there is an example for connecting a repository in Debian. But it is probably also suitable for Ubuntu, you should try it.
    https://www.mono-project.com/download/stable/#download-lin-ubuntu
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8900
    In fact, I would recommend using raspbian, because in my experience, all third-party systems most often have errors in the builds, since people do not pay enough attention to the work at 100%, simply because they can not test absolutely everything.
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8899
    Did you install Mono from where? Perhaps there is an old version in the ubuntu repository and there are errors on this?
    in reply to: Change event type color #8891
    Configuration Database-Directories-Event types
    Add your event and specify your color, or use the ones that are there
    In the input channel 177, use a formula like this
    Val();Val()>0? SetStat(177,116):SetStat(177,117)
    In this way, you change the channel status number to your own, to which the colors are linked.
    in reply to: Step by Step Guide for new project in Ubuntu #8884
    swapnilkumbhar – aburakhin@bk.ru
    My English is bad, I use an online translator 🙂
    in reply to: Developer in India #8883
    What do developers in India mean? you can install and configure Scada remotely, only a person who will connect the wires and an IT specialist are needed on site
    in reply to: Export input channel data #8868
    Open the project, open the input channels. File-Export the table, select CSV and perform the export
    in reply to: Step by Step Guide for new project in Ubuntu #8786
    Admin_Linux
    This mechanism does not work in Linux. I haven’t checked what doesn’t work yet. Raspberry is too slow a PC to configure scada directly on it, it is easier to run a project on your Windows PC and upload it to a remote server.
    in reply to: Step by Step Guide for new project in Ubuntu #8785
    The interface works, but there are some problems with the display and for the Linux version these mechanisms are disabled. For example, in the settings there are no drop-down menus with a selection of preset values, you must enter numbers. You can make a cheat sheet for all parameters and look at it when setting up, but this is very inconvenient. We expect version 6, where it will probably already work in the GUI on Linux without these inconveniences. All applications running under Mono run as written above, in theory, you can make symbolic links to run.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8784
    Change the owner for all folders and files in the folder.
    sudo chown -R user:group /path/to/dir/
    Where user is the new owner and group is the user group. -R indicates that the rights must be changed recursively.
    Example for Raspberry and install in /opt
    sudo chown -R pi:pi /opt/scada
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8782
    user_1000_0755
    on the remote server, I gave the entire scada folder to the system user with ID=1000, that is, this is the user that you create in the system, for example, for Raspberry Pi, this is the pi user. I also added this user to the www-data group just in case.
    • This reply was modified 5 years, 6 months ago by manjey73.
    in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8778
    Probably the folders above the level do not have the appropriate rights, and it does not even reach the final Config folder. Just doesn’t let it go any higher.
