Operating systems and virtual machine
Forum Home Forums Understanding the Software Operating systems and virtual machine
  • #7137
    Jan Pfeifer
    I have two questions:
    1) On which operating systems does Rapid SCADA run?
    2) Is Rapid SCADA running on a virtual machine?
    Thank you for your response.
    Best regards
    #7139
    1. Windows, Linux and should run on macOS, see https://www.mono-project.com/download/stable/#download-lin
    2. Works
    • This reply was modified 6 years, 1 month ago by manjey73.
    #7184
    Jan Pfeifer
    thank you for your help manjey73.
    @Mikhail
    can you confirm it?
    Best regards,
    JP
    #7186
    Windows and Linux – yes. VM yes. I have no info about Mac.
    #7187
    @manjey73 is quite experienced in Rapid SCADA.
    #7189
    I don’t use a MAC, but Mono is present on the site for this environment as well.
    https://www.mono-project.com/download/stable/#download-mac
    This means that you can run it on macOs, but the startup scripts will need to be reworked, since macOs is based on a BSD system, sort of.
    • This reply was modified 6 years ago by manjey73.
