Viewing 15 posts - 646 through 660 (of 981 total)
  • in reply to: Scheme copy #9347
    Download and install Extra Component Cheme.
    Activate it. Place the Frame component on the main diagram and specify the Address in its properties – ../Scheme/Scheme. aspx?viewId=35 where the viewId number corresponds to your view number. In the view settings, if necessary, set the checkbox to the hidden position.
    in reply to: Scheme copy #9344
    The frame is located in the extended components of the schemas. But I’m trying to figure out the link myself now, I don’t know how to do it correctly.
    in reply to: Scheme copy #9342
    Oops, try using a frame from additional circuit components. I somehow did not try to put one mnemonic into another…
    in reply to: Scheme copy #9338
    I use online translation for English and it is unlikely that I will be able to help with the help of messengers.
    When you have created the schema in the administrator, right-click-Open the location in Explorer.
    Make a copy of the file there and re-open the project in the administrator. You will see a new scheme, open it for editing and change the channel binding. This is path number 1.
    The way number 2 is to use offset for channels for an already drawn mnemonic scheme.
    Create Offset
    in reply to: Scheme copy #9336
    1. Copy the file to the Interfaces folder. Open a new file with the editor and change the channel bindings.
    2. If the channels are strictly sequential, you can refer to the same mnemonic scheme and specify the channel offset in the database settings-Interfaces
    in reply to: Scheme copy #9334
    And why did you upload the file? The question is what does it lie in?
    in reply to: Using PostgreSQL #9332
    Try version 5.8.3 there were changes regarding PostGre if I’m not mistaken. Only use the Modbus driver from version 5.8.2 (some error there)
    in reply to: Scheme copy #9331
    The entire mnemonic scheme is copied as a whole file with the renaming of the last one. And you can also call the same mnemonic circuit and specify the channel offset in the interface, like the example was in the documentation. But this is strictly for typed mnemonic circuits. Or what exactly is it about ?
    in reply to: FX2N-20MR chinese semi-clon of a Mitsubishi PLC #9225
    If the RS232 port uses additional signals other than Rx and Tx, then cheap converters will not work. To do this, you need to have a connection diagram. The RS485 interface can also be soldered on the DB9 port, but again, you need to have a diagram of the interfaces of your PLC. It is worth contacting the seller of this equipment.
    in reply to: IEC61107 Protocol driver #9178
    Напишите мне на почту, найдете в информации драйвера.
    Я пришлю свои выделенные IP (рабочий и домашний)
    in reply to: IEC61107 Protocol driver #9174
    IEC62056-21 кажется это обновление протокола 61107, надо будет поизучать и попробовать на живом приборе.
    in reply to: IEC61107 Protocol driver #9173
    По описанию на ACE6000 у него не 61107 а DLMS/COSEM
    in reply to: IEC61107 Protocol driver #9171
    @Yatran сможете организовать удаленный доступ к приборам для тестирования?
    И есть ли на них документация производителя о типах запросов и логи например с OPC сервера или перехваченные логгером порта в текстовом и HEX виде ?
    На русском форуме тоже тема есть.
    • This reply was modified 5 years, 4 months ago by manjey73.
    in reply to: Administrator Channel pane on LInux #9169
    This is disabled in Mono because it does not work correctly. Therefore, there are ids of other tables instead of a list. We hope that in the next version, if you abandon Mono, everything will be fine.
    in reply to: Signal Relative ID to Fixed ID ? #9167
    The signals and have a fixed numbering, but based on the indexes of the list of variables. And since we can change the lists, then what happens is what happens 🙂
