manjey73ParticipantTested on Kentatsu
Outdoor unit – KSUNA70HZAH1
Indoor unit – KSVA70HZAN1
manjey73ParticipantET = Ticks() - TpST[res];probably the forum engine replaced the minus with a dashCheck this line and the position in the file is referenced by an error
manjey73ParticipantThere should also be a Tiсks formula in the reference book, which all Timers refer to.
Also, the engine of this forum may spoil some characters when copying. See in the Server log which line in the EngineCS file the error refers to.
This reply was modified 4 years ago by
manjey73.
manjey73ParticipantDictionaries – See there – Event types
This reply was modified 4 years, 1 month ago by
manjey73.
manjey73ParticipantAt the moment I do not have the 5th version installed, perhaps it is called differently there. For example Additional tables
manjey73ParticipantConfiguration – Secondary Tables – Statuses
September 21, 2022 at 2:02 pm in reply to: How to show current date and time on scheme or dashboard #10865
manjey73ParticipantDateTime.Now.ToOADate()orDateTime.UtcNow.ToOADate()Date, DateTime or Time channel format
The channel formula is no different from version 5 in this case, supported as in .Net Framework and in NET6
manjey73.
manjey73Participantnetstat -ntulpWill show all ports that are in use and open. The latest version of raspbian may not have a package with this utility.
On Linux, port 10000 may be occupied by Webmin if you installed it. This is its default port
manjey73ParticipantChartPro allows you to open charts of several channels simultaneously with a monthly period.
Just try this plugin before buying, it will suit you or not, and then decide.
manjey73ParticipantYou will have to choose whether to look for solutions for CentOS or take the easier path. But there are always solutions.
manjey73Participantapt installThese are the commands of Debian, and distributions based on itIf you are new to Linux , then why did you grab CentOS ? The illusion of freedom? 🙂
manjey73ParticipantThe ChartPro plugin allows you to export to Excel
manjey73ParticipantYou probably need to redo the startup scripts, since they are written for Debian-like systems. Otherwise, there probably shouldn’t be any problems, since the entire system can be simply copied.
manjey73Participanthttps://codeberg.org/xye/xye That’s all I could find
it states “Tested with an old Midea CCM/01E and a Mundo Clima MUCSR-12-H8”
And also (e.g. FrigoLine, Mundo Clima, Daikin, …).Basically these are VRV systems. Perhaps Dantex
Unfortunately, there are no native air conditioners for testing. Only the AF-X converter to connect to Daichi.
September 13, 2022 at 7:41 am in reply to: How to add Chartpro plugin and use it in Rapid Scada version 6 #10733
manjey73ParticipantPlgChartPro30Min.xml do not pay attention to this file, it is an additional file for displaying my special channels.
Check the status of IIS at each step, perhaps it also turns off and gives an error when trying to start. It is also possible that some dll files are blocked by the system.
