Channel Number, Channel Value, Channel Status
Forum Home Forums Understanding the Software Channel Number, Channel Value, Channel Status
  • #10906
    victorlam
    What is the difference between Channel number, channel value and Channel status?
    Channel value = Channel Status?
    How can the user to determine the channel status? What is the criteria?
    #10909
    victorlam
    Or channel number status is only applied for event usage? How can I use the status of a channel number?
    What is the normal status value of the input channel number? For example:-
    Input channel number 101 = 10
    Input channel number 102 = 20
    Output channel number 101 = 1
    Output channel number 102 = 2
    Then what should be the normal input channel status for 101? 1 or 2 or 3 or zero??
    What should be the normal output channel status 101 here? 1 or 0 or undefined?
    What factor will be defined or determined for the channel status of input/output channel?
    Sorry, it might be confused between value and status here.
    #10910
    Configuration – Secondary Tables – Statuses
    #10911
    victorlam
    I tried to find the Configuration Database, there is no secondary tables – Statuses.
    May I know if I need to create a new table for statuses?
    Or there is statuses hidden at Administrator?
    Please advise where I can locate for this.
    #10912
    At the moment I do not have the 5th version installed, perhaps it is called differently there. For example Additional tables
    #10913
    Dictionaries – See there – Event types
    • This reply was modified 3 years, 5 months ago by manjey73.
    #10916
    victorlam
    Thanks! I can find the status values at event under Dictionaries here. I assume this is the location you mentioned.
