Viewing 15 posts - 301 through 315 (of 981 total)
  • in reply to: execute some external app from the web interface #15874
    online translation
    You can add Scripts to the table
    public double StartProcess()
      Process.Start(@"C:\SCADA\1.bat");
      Console.WriteLine(DateTime.UtcNow.ToString());
      return 1.0;
    and call this function in the output formula of the channel.
    Starting an external process is an unsafe action.
    in reply to: execute some external app from the web interface #15873
    There are always online translators, which we use successfully, I also don’t know English well 🙂
    in reply to: execute some external app from the web interface #15871
    Couldn’t fit in one directory 🙂
    in reply to: Modbus TCP Device ID #15826
    Addressing – start with 0 or 1
    It is possible to specify byte permutation for 4 and 8 byte data
    in reply to: New Scheduler Module V6.0.0.0 #15814
    I’m talking about the presentation table, two channels with the same tag code name are not displayed
    there 🙂
    And there is no need to talk about the channel, which is an output channel and has its own unique tag code.
    in reply to: modbus device communication error #15812
    You can probably create a calculated channel with the right length to accommodate your message. Specify it as Format = String.
    Specify that these channels are not saved in the database, so as not to waste space. And write a script that will write a line with your message into this channel when the signal = 1 is in the form of an ascii or unicode string.
    You can also add new enumeration text in auxiliary tables – formats. For example, for each device that you will have. It will most likely be
    it seems there are educational videos on youtube. There is also a Documentation section on the website.
    • This reply was modified 1 year, 10 months ago by manjey73.
    in reply to: New Scheduler Module V6.0.0.0 #15807
    It is better not to use the tag code to identify the scheduler. I added two channels, and only one of them was displayed in the table. I think the best option would be to make a choice from the list of channels, like it is organized in ChartPro, but even there it is not the best option. Calculating Fridays or Saturdays from the specified date and time is also not the best option. If the scheduler can work with any channels, then why should it identify itself? but editing tasks created by the scheduler would be very useful. There is also a question, commands can also be string, string HEX, string Date. can he send commands like that?
    in reply to: modbus device communication error #15802
    Tag code – Status (reserved name for driver)
    Format channel – Normal-Error
    Normal = 0
    Error = 1
    Need only one channel
    Data Type – empty
    in reply to: New Scheduler Module V6.0.0.0 #15792
    It is incorrect to use the same tag code for multiple channels on the same device. This contradicts the concept of Scada.
    The same tag codes are allowed on different devices.
    in reply to: modbus device communication error #15786
    Each device has a service channel with the Status tag code-0=Normal, 1=Error
    Just add a channel to the created driver and specify the Status tag code for it, select the Normal-Error format to display in text or leave D to display 0 or 1 as desired.
    in reply to: New Scheduler Module V6.0.0.0 #15785
    There are a lot of questions at once 🙂
    Big_Screen1
    1
    in reply to: modbus device communication error #15783
    If you wrote a script with an error, the Server will not start, you can see the cause of the error in the Server log, which is likely to be in CalcEngine.cs
    in reply to: New Scheduler Module V6.0.0.0 #15775
    OK, I downloaded it. But I don’t promise to try it out quickly. I’ve read the readme, but I’m still wondering if I need it. The auto-control module seems to allow you to do the same thing. Although the ability to make settings from the web is super. But according to the description, I still understood that it is necessary to use the Administrator application.
    in reply to: New Scheduler Module V6.0.0.0 #15773
    Please make the documentation available to the public
