Viewing 15 posts - 271 through 285 (of 981 total)
  • in reply to: Daily Archive #16038
    Well, you need to install ElasticReport first.
    And following his example, the xml in the sent ones should be replaced with the channel numbers that you have in the project. See how it will all be displayed in html.
    I didn’t understand much, to be honest. There you can change the names of channels, what exactly to output, and so on.
    in reply to: Daily Archive #16035
    Elastic_Report_Test
    Change my Elastic Report test configs there chlNum to your own and try it.
    in reply to: runtime8.0.相容問題 #16030
    您必须安装两个dotnet组件。
    You must have two dotnet components installed.
    in reply to: Daily Archive #16017
    unfortunately, I didn’t really figure it out myself 🙂 All the time, when I try to deal with him, I don’t have enough patience. And the primitive that I wanted to make didn’t suit me, because it doesn’t support it.
    in reply to: Daily Archive #16014
    Last Day report
    1
    Try to figure out the ElasticReport settings. I didn’t get what I expected from him, but in your case it might be different.
    • This reply was modified 1 year, 9 months ago by manjey73.
    in reply to: Daily Archive #16013
    If you do it in the form of a mnemonic, then you just need Calculation channels where you will copy daily data.
    But if you want flexibility, by analogy with regular tables, then you either need to refine them or make your own table plugin.
    Another way, as mentioned above, is to try a Flexible report and output it in HTML from the view.
    in reply to: Daily Archive #16011
    Well, in the current version, probably draw your own table in a mnemonic scheme. Alternatively, you can create your own web page where you can use js to pull out the data you need and connect it as a view.
    in reply to: Daily Archive #16007
    It seems to me that this is impossible. Most likely, this is how the regular table plugin works. Which can show columns of the selected time period only for one day, while reading archives only from the Sentinel.
    That is, in principle, he will not be able to make 30 or 31 columns based on the number of days in the current month. (or 28, 29 if the month is February)
    in reply to: Daily Archive #15999
    The project is not downloading. It leads nowhere. Can you put it on some kind of Google drive and give it a link?
    in reply to: Daily Archive #15990
    The server is running in UTC time, your time corresponds to UTC, maybe that’s the reason?
    Can you upload a primitive project with settings?.
    sometimes I don’t understand how it works either, I have to constantly calculate the time in my head 🙂
    in reply to: Daily Archive #15984
    Share the table settings, how did you create the column in just one day?
    It’s interesting to try. Perhaps the regular tables plugin itself can’t do this and you need another plugin?
    in reply to: Daily Archive #15982
    It’s not entirely clear what you want. Should I write the amount for that day in the cell of the Daily Database, or just the current value of the specified day?
    in reply to: HTTP Error 404.0 – Not Found #15955
    IIS runtime support (ASP.NET Core Module v2) Check that the module is installed
    You need a Hosting Bundle
    and
    .NET Runtime 8.0.11
    in reply to: HTTP Error 404.0 – Not Found #15952
    Do you have the version 2 module for IIS installed?
    Well, you have installed the necessary component for the WEB from ASP.NET ?
    in reply to: No sign-in #15950
    The administrator account allows you to send commands and sees all the views.
