qiuqiaoan
Participanthello mikhail
i figured out the reason:
the target .net framework of “scadaservershell” was 4.6.1 and the version for “scadaagent” is 4.7.2.
as shown below
.net framework versioni change the target .net framework of “scadaservershell” the build is OK. hope this will not lead to new problems.
August 21, 2020 at 7:35 am in reply to: push data to third-party station or another rapid scada station #7191qiuqiaoan
ParticipantHi mikhail,
1. i tried to modify the server IP. as below, but it going back to “Remote-Server”
when i upload the server.2. and what should be the Password be ?
<ConnectionOptions>
<Host>192.168.43.5</Host>
<Port>10000</Port>
<User>ModRapidGate</User>
<Password>672C3165774A308878A00927A987C759</Password>
<Timeout>10000</Timeout>
</ConnectionOptions>qiuqiaoan
Participanthello Mikhail,
i tried to use the “Automatic Control Module”, but i don’t see where i can set the command pulse duration. only a delay setting.and the pulse type command is very common and widely used in process control system. this should be a very basic function of the repaid system.
qiuqiaoan
Participanthello Eyad,
i need this pulse command function also.
have you solved this?August 13, 2020 at 11:33 am in reply to: push data to third-party station or another rapid scada station #7157qiuqiaoan
Participanthi mikhail,
thanks, for the gate module,
shall insatll on both server or only on the one pushing data.
do you have example on how to setup ?qiuqiaoan
Participanthello mikhail,
i have translated the following files, and sent to you by email.PlgDashboard.zh-CN.xml
PlgChartPro.zh-CN.xml
ScadaTable.zh-CN.xmlqiuqiaoan
i read the guide on how to translate. and i below circler3 have translated everything he/she can translate. seems the event part is not open for translate.
sorry, i did not make myself clear.qiuqiaoan
Participantqiuqiaoan
ParticipantThanks to both of you. based on instructions from both of you, I got it work.
but have following flaw (some data are missing)Mikhail,
would you please explain more on how to use the rolling mode, and how to put chart on scheme using extended scheme components. I already have the trial key for both dashboard and extended scheme components. I would like to see the advantage of this.qiuqiaoan
ParticipantThanks to both of you. based on instruction from both of you, I got it work.
Mikhail,
ParticipantHi, Mikhail
double (8bytes) worked. as shown in below link
read as doubleif I would like to convert the 20 bytes ascii string (they are all numbers) to number, so the values can be stored in the database and be shown on the chart.
do you have suggestion for that, any tested formular?thanks
qiuqiaoan
ParticipantDear Mikhail,
Thanks for the quick reply. i tested it according to your way and works good.
but, actually in my case i have 4 inputs called Opened, Closed, Opening, and Closing. and I need to display this status by one text.
so the fake code could be like:if ((Opened) && (!Closed) && (!Openning) && (!Closing)) { return "Opened"; } else if((!Opened) && (Closed) && (!Openning) && (!Closing)) { return "Closed"; } else if((!Opened) && (!Closed) && (Openning) && (!Closing)) { return "Openning"; } else if((!Opened) && (!Closed) && (!Openning) && (Closing)) { return "Closing"; } else { return "Error"; }and i have several same equipment, so i want to reuse the code (folumar).
i see alarm;Armed;Disamed:Fired;Normal in the Units table which maybe is similar to my case, but i don’t know how to do.IN GENERAL, IN MY SYSTEM I WILL NEED TO DO SOME LOGICAL AND MATH CALCULATION BASED ON DIGITAL AND ANALOG INPUTS AND SEND OUT COMMAND BASED ON THE CALCULATION. DO WE HAVE SOME GUIDE ON HOW TO THIS ?
Thanks in advance !
