hello mikhail
i got the code from github. open by vs2017.
have switch to release configuration and following the sequence in “HowToBuild.txt”
but when i come to the ScadaServer solution. i got errors in the “ScadaServerShell” project. i feel the reference is right, but the build is reporting missing reference.
as show in the picture.
hello mikhail
i figured out the reason:
the target .net framework of “scadaservershell” was 4.6.1 and the version for “scadaagent” is 4.7.2.
as shown below .net framework version
i change the target .net framework of “scadaservershell” the build is OK. hope this will not lead to new problems.
