tom040264
Viewing 9 posts - 31 through 39 (of 39 total)
  • in reply to: Web Page don't open in other computers. #1911
    tom040264
    It seems as if it is a small misunderstanding. I understood, that Rapid SCADA has an integrated WEB-server, and the other computers hold the data from it.
    I have no web server, neither i my home network, nor in the internet.
    in reply to: Web Page don't open in other computers. #1907
    tom040264
    The access from any computer within the home-network to the SCADA server works perfect, but how can I access the server from the internet? I’ve opened a port 10000 on the router/modem, and on the SCADA server (a new rule in the firewall). I have a static address (via dyndns). Then I tried with:
    http://xxx.dyndns.org:10000
    but it didn’t work. Is it enough just to open the port? Which application should I start behind this port.
    Thank you!
    BR
    T.
    • This reply was modified 9 years, 10 months ago by tom040264.
    in reply to: Visual Studio #1868
    tom040264
    Hi Mikhail,
    You are fully right. This was the reason.
    Thank you
    T.
    tom040264
    Hello Mikhail,
    I have a “basic question” (there are no stupid questions): after I have connected the module ModDBExport.dll, which program can I use the SQL data base with? I have found the description in dbexport_en, but honestly speaking I don’t understand is it a mater of Administrator or Communicator.
    Thank you in advance
    T.
    in reply to: FS20 and FHZ #1785
    tom040264
    Hello Mikhail,
    The problem is, that there is not so much documentation in English regardin FS20, or I can not finde it. Here is a link to something what could give you the overview:
    http://fhem.de/commandref.html#FS20
    Another question: can Rapid SCADA read something from a text file and visualise it as a text variable? I haven’t fine anything about this in the documentation or in this forum.
    BR
    T.
    in reply to: New database #1759
    tom040264
    Thank you Mikhail, it works!
    The modbus device is connected. The next step is to connect the FS20 system from contronics, but I have absolutely no idea where to start.
    Br
    T.
    in reply to: Access SCADA-web configurator #1748
    tom040264
    Hello Sergey,
    Can you help me plese? I have the same problem and cann’t finde the way to display any charts or pictures.
    BR
    T.
    in reply to: Access SCADA-web configurator #1743
    tom040264
    First of all thank you for the quick response. This is clear, but how can I get to the Web configuration mask/form like in the User Manual described? I have found no way there.
    T.
    in reply to: Access SCADA-web configurator #1741
    tom040264
    Hello Mikhail,
    I did login the Webstation app as administrator, went to Main Menu > Configuration > Web application, but I was able to see only the status of different plugins (Active) and had the possibility to deactivate them.
    How can I start any of these plugins, e.g. Web Configurator?
    T.
